here and
here.
Code: Select all
Imagine having a 10-gigabyte hard drive in your cellphone or a terabyte of space on your laptop.
Code: Select all
Conventional longitudinal recording stores data on a magnetic disk as microscopic magnet bits aligned in plane. Although advances in magnetic coatings continue to improve data recording densities on HDD, when the densities become too extreme, the magnetic bits repulse each other due to in-plane alignment. Squeezing more bits on to a disk will eventually reach a point in which crowding degrades recorded bit quality. As such, HDD manufacturers face fast-approaching limits on storage capacities.
By standing the magnetic bits on end, perpendicular recording reinforces magnetic coupling between neighboring bits, achieving higher and more stable recording densities and improved storage capacity.
