BRABUS STEALTH
BRABUS STEALTH
R&T ARTICLE
I have been working so much I didn't notice the new issue of R&T that has been sitting in the basket next to the crapper in the bathroom until this morning. Found this Brabus sweet stuff! I don't mind the 20s on this one considering the 15" front rotors w/ 8pots and 974 lb.-ft. of torque at 2100 rpm! :shock: Okay, back to work w/ me!
Re: BRABUS STEALTH
sirwilliam wrote:Okay, back to work w/ me!
from your other thread this morning:
I can't remember if this was already posted but I thought I would share one more...okay, now back to work!
you lying, slacking sumbitch :lol: .
Re: BRABUS STEALTH
I can't even imagine having almost 1000 lb-ft at 2100 rpm.
Driver's Manual wrote:Do *NOT* drive in rain. EvAr.
Re: BRABUS STEALTH
Well, I started w/ one thread post and ended up w/ 3. Little breaks are good. :D
Re: BRABUS STEALTH
The only problem is that you won't likely ever get that power to the road.
Did anyone ever see the Top Gear Brabus S V12 Biturbo Roadster.
730 hp and over 1000 lbft. (limited to 811 lbft in 1st gear)
Basically worthless around a track because when you start off the traction control just goes nuts the whole time and when you turn it off you can't turn. So to go straight you have to have the traction control off but to turn you have to have it on.
Worthless.
Re: BRABUS STEALTH
needs more awd. 8)
Re: BRABUS STEALTH
dyno queen :notcool:
Re: BRABUS STEALTH
Dear god, that thing is a beast...
Re: BRABUS STEALTH
Post by avriette »
drwrx wrote: Worthless.
Sometimes, even when you know it's not the right tool, it's fun to use a sledgehammer instead of a screwdriver.
Re: BRABUS STEALTH
avriette wrote:Sometimes, even when you know it's not the right tool, it's fun to use a sledgehammer instead of a screwdriver.
didn't MC Hammer have a gold plated sledge hammer? :wiggle:
Re: BRABUS STEALTH
These are the times in which I sit and think about what it would be like to have more money than taste or brains.
