17 bbs
Looking for something? Throw it in here!
Phil
17 bbs
Post by Phil »
Looking for 17" BBS for my wrx, need new tires asap and want to upgrade wheels. Thanks in advance,
Phil
Phil
Re: 17 bbs
Honestly, as much as I love the BBS (especially the 04s) there are better buys to be had, both lighter and less expensive.
The 04 BBS are becoming very rare and pricey.
Phil
Re: 17 bbs
Post by Phil »
Yeah and new ones are butt-expensive. I don't want anything that looks TOO custom, but any recommendations for a silver 05? Leaning towards silver wheels. Rota? I don't want anything too 'open' so you can see my lack of brembos. - Phil
Phil
Re: 17 bbs
Recommendations:
Enkei Racing RPF1 (15 lbs): $225 each (damn light)
Enkei Racing J10 (16.5 lbs): $130 each (light)
Kosei K1 TS (14.5 lbs): $195 each (crazy light)
WedsSport SA-90 (20 lbs): $209 each (pretty)
MB Weapon (18 lbs): $110 each (cheap & pretty and fairly light) look like WedsSport SA-90
MB Mesh X (20.5 lbs): $105 each (really cheap & really pretty)
MB Gear (20 lbs): $125 each (cheap & pretty)
Rota Grid (17.5 lbs): $160 each (cheap & pretty and fairly light)
Rota SDR (18 lbs): $160 each (cheap & pretty and fairly light)
Rota SDX (17 lbs): $165 each (cheap & pretty and light)
Rota Slipstream (20 lbs) $160 each (cheap & pretty)
Rota Tarmac II or Tarmac III (19 lbs): $160 each (cheap & pretty)
Rota G-Force (18 lbs): $160 each (cheap & pretty and fairly light)
Rota SVN (20 lbs) $170 each (cheap & pretty)
Rota Torque (17.5 lbs): $160 each (cheap & pretty and fairly light)
These are based solely on my personal preferences. I stay away from really expensive and really heavy wheels.
Re: 17 bbs
RPF1's or SSR's :)
Re: 17 bbs
One more choice would be:
Team Dynamics Pro Racing 1 or 1.2 (16 lbs): $150-$175 each (light & cheap & pretty)
As much as I love SSRs, like the Type C-RS, they are crazy expensive (around $400 a pop) and finding 17"s is becoming difficult. I couldn't in good conscience recommend someone paying nearly $2,000 for wheels when you can get an excellent set for nearly one-quarter the price!
Phil
Re: 17 bbs
Post by Phil »
Thanks for the info guys, any recommendations on who can order/install everything?
Phil
Re: 17 bbs
P-Tuning can either order or install everything you need.
They have a wonderful set of tire machines, including road-force balancing IIRC.
Phil
Re: 17 bbs
Post by Phil »
P-tuning says they can't order Rotas, they get their wheels from Machen? Macken? Any recommendations from where I can order my rotas from and get em shipped to P?
Phil
Re: 17 bbs
Rota's are great wheels but they're really heavy (and I know, I've rocked a set since the WRX was 2 months old). I'd recommend something lighter for summer use and Rota's for winter/pothole season.
Subydude is a good vendor and has a large selection of Rota wheels. I also think Mach V carries them if you're looking for a local vendor.
PTuning rocks, I get everything I can from them. good people deserve to be supported. :wink:
Re: 17 bbs
Not all Rotas are heavy:
Any 17" wheel 18 lbs. or under is pretty light, and Rota makes a number that are.
SubZero: 16.4 lbs
Grid 17.5 lbs:
SDR 18 lbs:
SDX 17 lbs:
G-Force 18 lbs:
Torque 17.5 lbs
All these are 17" x 7.5" if you get the 17" x 8" expect them to weigh another half pound or more per wheel.
If it's all about price, pick the Rotas you want then do an exhaustive on-line search and you may find a screaming deal.
Some time ago I was looking to get a set of Grids and found a wheel site that dealt mostly with Hondas and Miatas but they carried Grids for $150 less per set than any other vendor I could find. It was like getting a wheel for free.
However, Subydude does carry some that few other places carriy (SDX are a good example).
In the end, you makes your choice and you spends your money.
Re: 17 bbs
4 Rota Tarmac! Excelent Condition Good Tires $500
http://forums.nasioc.com/forums/showthr ... ?t=1535379
The wheels are gun metal, the tires are Sumitomo HTRZ II
Not a bad deal for $500
Re: 17 bbs
That's a great deal!
Re: 17 bbs
drwrx wrote:4 Rota Tarmac! Excelent Condition Good Tires $500
ask and ye shall receive. the good Dr strikes again. :mrgreen:
Re: 17 bbs
I do want to say one thing about wheel weight; I'm a bit of a weight weenie when it comes to wheels, however, knit-picking over a pound or two isn't worthwhile when you consider your going to strap on a set of tires that are likely to be around 25 lbs each. So now the two pounds you sweat so much about is nearly meaningless.
Example:
20 lb wheel (at $105) vs 16 lb wheel (at $250) = 25% weight increase (but a $580 savings, free tires mounted and balanced)
20 lb wheel (at $105) + 25 lb tire (45lbs) vs 16 lb wheel (at $275) + 25 lb tire (41 lbs) = less than 10% weight increase.
And your still paying the extra $580.
