Anyone interested in a Thermaltake 850 watt ATX power supply?
-scheherazade
						[OT] FS : Thermaltake Toughpower 850 watt ATX Power Supply.
				scheherazade
Re: [OT] FS : Thermaltake Toughpower 850 watt ATX Power Supply.
jesus christ.  850 watts?  were you trying to build the most powerful home computer ever?
				scheherazade
My last psu was an enermax galaxy 1000 watt
I'm actually trying to switch to distributed power, and use twin 650 watt psu's.
It spreads out the power/temperature and keeps fans spinning slower.
My computer is all right.
qx9700
8 gigs ddr2 800
twin 8800 gtx (sli)
few other bells and whistles.
(1.5 years old now)
The 8800's are insane-o-hot under load... coupled with 680i chipset (something crazy like 80c idle), and my case temps are really high.
Higher temps = higher fan rpm = noise.
I'm going over my components and coming up with ways to spread the heat around.
-scheherazade
qx9700
8 gigs ddr2 800
twin 8800 gtx (sli)
(1.5 years old now)
-scheherazade
<neo>whoa</neo>
Good luck man, it sounds like you've built yourself quite a task.
the 8800 series are notoriously "warm" under load. i run a single gtx (probably going to sli once the 9000 series is released and the 8800s are cheaper) and i notice how warm my room is with just the computer on. chuck runs a 8800gt and seems to be having cooling problems.scheherazade wrote:My last psu was an enermax galaxy 1000 watt
qx9700
8 gigs ddr2 800
twin 8800 gtx (sli)
(1.5 years old now)
-scheherazade
				scheherazade
9 series is so cheap..
$270 for a 9800 gtx.
The 8800's cost more than the 9800's.
http://www.tigerdirect.com/applications ... C-SHOPPING
The speed is about the same between the 8's and the 9's... (8's even are faster in some cases). It was a really disappointing product for me. I got used to nvidia doing the ol' +40% speed every generation. Good thing is that I'm not aching to upgrade to the 9's (saving $).
-scheherazade
-scheherazade
				scheherazade
