WTB super duper cheap VF39 turbo
- Bluestreak2006
I have decided that what's left of my cash could go the way of a turbo. Im gonna take Darren's advice and just go with a VF turbo and cheap IC as I can just get a free Cobb map to hold me over. So if any of you guys want to help a guy out let me know. Also Darren what should I expect to pay?
Jay
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
Depending on the condition, the used VF39s go for $250-$400. I would recommend getting one w/ less than 20k miles and no shaft play. Make sure that all the lines are included as well. Loved my last VF39. Can't wait to get my 18G on. Good luck!
- Bluestreak2006
Yeah, Ben! You really need that TS FullRace 30/35R setup!Bluestreak2006 wrote:Nobody. Ben when are you gonna do an upgrade.....
Watch the NASIOC "for sale" boards like a hawk!
However, I wouldn't spend more than $450 on any used vf series turbo if it were me.
If your willing to put in a liitle extra work you can get a new TD05-16G "oil cooled only" for $499!
Look here:
http://forums.nasioc.com/forums/showthr ... ?t=1400701
It requires re-routing the coolant line that would run to the turbo down back into the block.
I run a similar set-up on my WRX (Greddy TZ18G).
You just need to remember to let the car idle a bit before shutting it off (or install a turbo timer like me).
You can also get a new TD05-16G for $650 from ForcedPerformance:
http://store.forcedperformance.net/merc ... =WRX-Turbo
Look here:
- Bluestreak2006
Honestly, I think $300 is a bit steep, especially given that "pieced together" pipe may not hold pressure. Which menas you would likely have to pay another $50-$100 to get the correct hoses.
I understand the desire to get the STi TMIC, but if your paying much more than the $200 you can get the SSautochrome TMIC for new, than it's probably not worth it.
Closer to $200 and I'd say go for it.
- Bluestreak2006
$190
http://www.ssautochrome.com/level.itml/icOid/1437
it's at the bottom of the page.
I would call to make sure you get the hoses with it.
- Bluestreak2006
- Bluestreak2006
Without a proper tune there will be no (noticeable) gain from the addition of a bigger TMIC. Ideally it should cool the intake air a bit better and won't heat soak as fast. Most of the data I've seen indicate that larger TMICs add about 8-14 whp with a proper tune. The benefit of a larger IC is that it allows you to get the most out of a larger turbo.
And for the record that AVO TMIC is probably the best I've ever seen. In hindsight I should have never sold it. Great quality, great fitment, great everything!
- Bluestreak2006
VF43 does have the crack issue but I thought the only difference was the slightly larger internal wastegate that helps w/ creep? I would definitely grab one for $400-450 if only 6k miles and no problems.drwrx wrote:I'd grab that in an instant, $450 isn't too bad a price.
I actually like the vf43 more than the vf39. It appears to make a bit more power (just a bit), and doesnt appear to have the cracked housing problems.
- Bluestreak2006
- Bluestreak2006
So, did you ever get that vf43?
there's a TD05 Evo III 16G available here:
http://forums.nasioc.com/forums/showthr ... ?t=1482673
