ODBII scanner...
Installing or configuring? Want some more bass in the Subaru? Come on in!
ODBII scanner...
Hey all,
Anyone have a ODBII scanner that I can use? Suzie's Honda threw a CEL this morning and I wanted to check to see what it was.
Thanks,
Julian
hotsam
Post by hotsam »
Got one...
Where are you located? Anywhere near Springfield?
BTW, will AutoZone or something tell you which code was thrown? I know they test batteries, but this is a little different, haha.
I think that AutoZone will read codes for you, but I've never tried personally. I wouldn't mind checking to see if I'm throwing a code that the AP is suppressing. (still trying to learn what I'm doing)
WANGAN_X
Post by WANGAN_X »
yes autozone and advanced both read and tell, they will not erase the code however
That's fine if they don't erase it... Depending on what the problem is, she might be going to a shop anyway.
scan me
Gimme a call and I can come over tonight after work and use Jason's scanner.
Goes for you to, Gabe, it logs stuff.....
hotsam
Post by hotsam »
I'm in Hoodbridge. But we could meet up.
Re: scan me
zaxrex wrote:Gimme a call and I can come over tonight after work and use Jason's scanner.
Yea, BTW, I want that back at some point. :)
OK, it never leaves my car. Next time you see my car it can be yours again with a simple reminder.
Heck, I'll even show you how to use it. :o
I keeeed I keeeeed.
zaxrex wrote:Heck, I'll even show you how to use it. :o
Yea, that would help, since I had it for about two weeks before I loaned it to you like a year ago :)
did somebody say it logs? that's the next thing I want to do: datalog what's going on so I can fully understand what my baby is doing. the dyno day was just a part of the equation. Zack, I'm not ready for 2 ECUs and 2 laptops in the car but I'm taking my first baby steps... :mrgreen:
gsx-lex
Post by gsx-lex »
If you are interested in logging through an OBDII port, I highly recommend the Pocketlogger (www.digitaltuning.com). This is pound for pound the best OBDII datalog out. I think that everyone sohuld have one just to get a feel for whats happening when tuning.
I used pocket pocket logger to dyno tune anything that comes in with an AFC and is OBDII. Without some sort of data loggin, your just tuning blind.
Have turbo, will spool.
I <3 Lesbians
Pocketlogger is great if you own a Mitsubishi but the sampling rate for Subarus is MUCH lower (6 vs 11 - 20 depending on model). I looked into this when I had my Civic Si. I think it's a great product, just not for my specific auto. :(
OBDII data rates vary between 6 and 20 depending on the car. PocketLOGGER's unique Byte Timing controls allow the user to optimize the data rate no matter what car or PDA you have. The worst car we have found is the Subaru WRX which can barely maintain 6 samples per second.
^^^ As much as I hate to say this, almost seems like a failure on Subaru's side not to sample fast enough for ODBII. I'm VERY suprised this isn't in the standard.
