Winter wheel & tire setup, sweet
http://washingtondc.craigslist.org/mld/ ... 73456.html
may be gone already, but thems some nice wheels and you get free tires with them.
Funny story:
Repair shop -- "we can't get your replacement wheels that match your non-damaged one, do you want us to get three different ones?"
Me -- "Ahh, no"
Repair shop -- "OK, then you need to get your own replacement wheels and we can reimburse you up to $730."
Me -- "Ahh, OK"
So I got a message into this guy and another one out to a guy in CA that has the same P-7s as mine but with winter tires.
If both of these fall through, I'm just gonna get a set of sick ultra-high performance tires and a spec allignment at p_Tuning...
THIS IS NOT MY JOB, PEOPLE! The shop gets paid by the insurance company to do this. I don't.
Me -- "Ahh, no"
Me -- "Ahh, OK"
Tire Tack just tested a new Sumitomo HTR Z III Max Performance Summer against the Bridgestone Potenza RE050A Pole Position, the Continental ContiSportContact 3 and the Yokohama ADVAN Sport. All excellent tires!zaxrex wrote:If both of these fall through, I'm just gonna get a set of sick ultra-high performance tires and a spec allignment at p_Tuning...
The Sumitomo recieved the highest score and had the best performance in every dry performance category and was just behind the others in wet. and here's the kicker price: 225/45ZR17 $90.00 (each)!
the others: $135, $160, $180! Yep, HALF! Damn Impressive.
Looks like I found my next summer tire
Thanks Darrin!
- Phibs
The HTR ZIII may be a step down from what you are currently running on.
The Advan Neova (classified as an Extreme Performance Summer tire) is a step up on the Advan Sports (Max Performance Summer tire) The Neova really is a track tire that doubles as a street tire, much like the Hankook Ventus R-S2 Z212.
If you really like the Advan Neovas but don't want to pay $200+ a pop each than you may want to consider the Hankook Ventus R-S2 Z212 which would be about $100. The Z212 were the number 2 ranked tire on dry behind the Neova by Car and Driver's 12 tire shoot out (I can e-mail a pdf file I made of it if you want). The Z212's wet traction was at the lower end of the scale however, 9th out of 12. But they are probably the best bang for the buck in that class of tire.
The Falken Azenis Rt615 are another great dry tire, that do wondrs on track days, but they're wet performance is abyssmal and thus can't get a recommendation from me as a true street tire.
As always, it comes down to $$$ when I'm ready to buy. I'm VERY happy with the Neovas, but they are pricey.drwrx wrote:The HTR ZIII may be a step down from what you are currently running on.
- Tricycle
Also look at the soon to come out Toyo R1-R, and Kumho XS both are due out early next year and should be about the same level as the Advan Neova/Azenis/Z212/RE-01rSabre wrote:As always, it comes down to $$$ when I'm ready to buy. I'm VERY happy with the Neovas, but they are pricey.
moxnix - street tire racer.
I've heard good things about the upcoming Kumho XS. The Falken RT-615 was the benchmark and supposedly their test driver was consistently faster on the Kumho. Internally the tire has been known as the FK (Falken Killer). The test driver was also supposedly faster on the new Kumho over the Bridgestone RE-01R, which is an amazing tire in performance.moxnix wrote:Also look at the soon to come out Toyo R1-R, and Kumho XS both are due out early next year and should be about the same level as the Advan Neova/Azenis/Z212/RE-01r
Here's a pic of it from the SEMA show:
My fear is that it will be a poor wet tire much like the MX
What, can't you see the water evacuation sipes? No, neither can I...
So the insurance company is being dumb. I'm just going to throw the towel in and get a set of the HTR Z III in 225/45-17 or 235 since they are going on 7.5 wheels and would be better for stopping. Maybe be a little squirmy on turn in, eh?
- Tricycle
The reason for the offset circumferential grooves being closer to the outside is for better wet weather performance while continuing to have good dry grip.drwrx wrote:My fear is that it will be a poor wet tire much like the MX
I used to run the MX on my old car and I thought wet grip was actually pretty good.
Sadly, every test on the Kuhmo MX I have ever seen puts it at the bottom on wet. Tire Rack has tested it 4 times and it is always the worst in wet traction. The Car and Driver review refered to the MX as "far to easy to send it sliding yet took seemingly forever to recover and regain traction. While it's dry times put it near the middle of the most of the tests, it's poor showing in every wet test put this tire dead last."moxnix wrote:I used to run the MX on my old car and I thought wet grip was actually pretty good.
- Tricycle
That Dec 05 C&D test gave very poor marks to the Z212 in the wet also. If the test you are talking about was done under the same conditions as the Dec 05 tire test with all tires set to the same pressures (car maker recommended pressures) then I am sure the floppy sidewall of the MX had something to do with those ratings. I feel that C&D tire tests are about 1 step above Consumer reports tire tests (and I think the Falken Zeix 512 is the worst rain/snow tire ever so that should tell you how much I trust CR)drwrx wrote:Sadly, every test on the Kuhmo MX I have ever seen puts it at the bottom on wet. Tire Rack has tested it 4 times and it is always the worst in wet traction. The Car and Driver review refered to the MX as "far to easy to send it sliding yet took seemingly forever to recover and regain traction. While it's dry times put it near the middle of the most of the tests, it's poor showing in every wet test put this tire dead last."
The MX is a little old now but when it came out the tirerack tested it and it beat both the BFGoodrich g-Force T/A KD and the Yokohama AVS Sport (top tires at the time) in the wet so I see no reason that the new XS would not be a top wet performer also when it comes out since tire technology has greatly improved since then.
At the time tirerack said this about the MX "On the track in the wet, the Ecsta MX continued to provide responsive handling, along with good cornering and braking traction. This made the Ecsta MX easier to drive at the limit and allowed it to turn the fastest lap times of the three tires."
