Turbo Inlet
- Phibs
Turbo Inlet
Would an aftermarket turbo inlet hose/kit help at all with my 2005 STI w/ larger turbo, tmic, injectors and fuel pump? I remember the stock inlet hose being suck and in my efforts to do things 'right' I'd like to replace it if that will help at all.
Bryan
2012 WRX 5-Door Limited
based on my experience, it's an awful lot of work (removing intake manifold, etc) for very little gain. I'd recommend against it unless you were at teh point where the inlet is the bottleneck in your system. I don't think you're at that point yet.
just my .02usd
just my .02usd
- Phibs
- hotsam
FYI: The install takes around 5-6 hours. The time to do it is when you are swapping a turbo and then it only adds about 2 hours.
Basically, you have two options: Cut the old one out or take the intake manifold off.
The only reason to replace it is if you ripped the OEM one during a turbo install, you have collapsed it, you need a 3" inlet for a turbo or you are sadistic.
It will not help with spool
- Phibs
