Larger TMIC
- Phibs
- Phibs
Did the hotside swap, anything look abnormal:
http://bsd-unix.net/gallery/v/NewTurbo/
Need to get the mounting bolts off the old hotside and on the new one.
Need to get proper pin for actuator arm it seems too
Bryan
2012 WRX 5-Door Limited
Looks good from the photos. Bring it to lunch thursday and I'll look it over.
To remove the studs all you do is screw a nut onto the stud and then another on top of the first, then rotate the bottom nut. The stud will back out of the housing. I can show you that on thursday too.Phibs wrote:Need to get the mounting bolts off the old hotside and on the new one.
Did you damage it taking it off? It doesn't need a lot of force to keep it in place. You might want to take it to a harware or auto parts store.
- Phibs
- Phibs
Received these today:
http://www.rallysportdirect.com/shop/po ... p-791.html
Looks like I am set to go? Now I just have to figure out which one of you kind souls can help and when
Bryan
I think we'll need a group effort on this.
Turbo, headers, injectors and TMIC can be an all day affair.
Ideally we should have two people working below on the headers and removing the down-pipe. And two people working up-top on the turbo and injectors.
I'm happy to help with the turbo, headers and downpipe, but it would be my first set of STI injectors, so I'd really want someone there who has done them before.
Some deep well 12mm and 14mm sockets would be nice.
Sadly, that's one thing I don't have.
Do you have your 850cc injector MAP ready for upload and a tuner set-up yet?
Yep... without that map, there is no sense in doing any of it.
- Phibs
- Phibs
- Phibs
Anyone know where I can get the Oil line adapter needed for the STI and an FP turbo? Mach5 did not seem to carry it and gruppe-s has not gotten back to me. I'd like to do the install some time this year so any help would be appreciated. ( The FP part is not required as it is overpriced IMHO, but I will
get it if no other parts exists that will satisfy the requirement)
Bryan
You "may" not need it. Julian could chime in as to whether his required it or not. It looked like his used the stock oil intake line. However, while yours and his are basically the same (TD06-20G) there may be subtle differences. The oil intake line may be one of them. You would hate to be that far into the install and then not be able to finish.
Again, if you have a MAP ready for those injectors, the install could take place any saturday. Ideally, I'd want one if not two more people to help.
- Phibs
I'm not sure if his turbo would need it or not and I'd hate to say one way or the other and have it be wrong
The SZ55 doesn't need a new oil line though. Take that for FIW.
- Phibs
- Phibs
This is what gruppe-s said:
Hi Bryan,
I looked into this and you can install the turbo without any additional
parts. The stock oil line just needs to be bent slightly to meet up with
the FP turbo's oil return port. The adapter is actually just a braided hose
replacement for the hard line. Sorry for not explaining this to you more
clearly.
Thanks
Max
www.gruppe-s.com
Hi Bryan,
clearly.
Thanks
Max
www.gruppe-s.com
Bryan
- Phibs
From FP:
Bryan,
Our oil feed line is not an adapter kit, it is a complete replacement of the
stock oil feed line. You can reuse your stock oil feed line with our turbos,
however we do recommend purchasing our SS flexible oil feed line especially for
the 20g and larger turbos. Due to the larger physical size of the turbo, you
may have to do some bending of the stock hard line and when you do that you run
a high risk of creasing or cracking the stock hard line. Switching to our SS
flexible line just helps to ease the installation of the larger turbo. If you
have any other questions, please let us know.
Thank you,
Amber
Sales Team
Forced Performance
972-984-1800
www.forcedperformance.net
Bryan,
Thank you,
Amber
Sales Team
Forced Performance
972-984-1800
Bryan
- Phibs
- Phibs
