We got quite a few deals for you this fall, so lets get started:
Maintenance Packages
30K
Mobil 1 Fully Synthetic 10W-30
OEM Oil Filter
Red Line Lightweight Shockproof Transmission Fluid
OEM Rear Differential Fluid
OEM Fuel Filter (If necessary)
Coolant
Tire Rotation
Brake Inspection
$300
60K
30k + spark plugs
$350
Timing Belt
$175
Brake Packages
WRX/STi Brake Kits
Our Hi Performance brake kits take all of the guess work out of putting together an aggressive street/track setup. These kits include the highest quality parts and have all been tried and proven for years.
This combo is as aggressive as you can get before you are eating up the Rotors. This combo is a monster on the street and track. Many of our sponsored cars runs these pads on the street and then rip around on the track. Please be aware of the fact that these pads do tend to squeak a little when cold but their stopping power more than makes up for it.
All kits include:
Front and Rear Centric HP Rotors
(with your choice of rotor configuration ie; blank, slotted, cross drilled etc...)
Front and Rear Hawk HPS Pads
Technafit SS Brake Lines
ATE Super Blue Brake Fluid
WRX $635 Installed
STi $899 Installed
WRX/STi Line + Fluid Combo
$150 Installed and Bled
Tanabe GF210
The GF210 coil spring is geared towards maximum performance, without compromising daily driveability. A subtle drop provides an aggressive stance, while the higher spring rates (+20% - 30% over stock) provide excellent handling and vehicle stability characteristics.
$400 Installed AND Aligned
Exedy Stage 1 WRX/STi Cluch Kit
This kit utilizes a full face organic disk with a high performance pressure plate. You can expect a slightly higher pedal pressure with this kit but it is absolutely streetable and will hold up to more than the stock unit could.
This kit comes complete with pressure plate, disk and throw out bearing.
$900 Installed, flywheel resurfacing included.
Any clutch ordered off of our website comes with a FREE stainless steel clutch line.
http://www.vipgarageonline.com/store...utch_Kits.html
Megan Racing Catless UP/DP Combo
The Megan Racing Downpipe for the WRX/STi is one of the best values on the market. It's true 3" Stainless Steel design will allow for maximum performance with superior quality. Help your turbo breathe today.
You can expect significant gains when combined with a quality cat-back exhaust and tune.
Includes all installation hardware necessary.
$500 Installed
Any and all questions welcome.
Thanks for your time.
-Luke
VIP Garage
45763 Elmwood Ct
Unit 140
Sterling, VA 20166
Shop: (703) 433-2400
Cell: (703) 587-2992
AIM: VIPGarage Luke
sales@vipgarageonline.com
