New Brakes
New Brakes
Mine have finally started singing me their Swan Song so I'm in the market for new front brakes. I wanted to know if you guys had any suggestions or if I should just pick up whatever I can find at Advance AP. If possible, I'd like to find something that doesn't produce as much noticible brake dust as the stock brakes.
I know Matt (Not Thermobox) has ones that are VERY good for brake dust. I have Porterfields and love them. A little less brake dust than OEM and the stopping power is great!
Sabre wrote:I know Matt (Not Thermobox) has ones that are VERY good for brake dust. I have Porterfields and love them. A little less brake dust than OEM and the stopping power is great!
- hotsam
Re: New Brakes
I say get some nice 2 piece DBA rotors w/ new HPS or Porterfield pads. Get less brake dust and less mass for better braking.Libra Monkee wrote:Mine have finally started singing me their Swan Song so I'm in the market for new front brakes. I wanted to know if you guys had any suggestions or if I should just pick up whatever I can find at Advance AP. If possible, I'd like to find something that doesn't produce as much noticible brake dust as the stock brakes.
Or you can get some nice ALCON 6 or 8 pot fronts and 4 or 6 pot rears w/ pads and 2 piece rotors.
Or you can shell out around $10k-$15k for some nice full ceramic setups (not sure about dust on those)...that would net you some nice braking
Speaking of which, I need to put on my two piece front rotor's... hehe
^^HOT SAM always hooks me up and is great to deal with. I would check w/ him to see what he has.Libra Monkee wrote:Thanks for the input! Now, any suggestions on vendors?
I bought my Porterfields from private sale... too bad Oakos doesn't sell them! They do sell Carbotech's though
I'd highly recommend doing brake fluid and lines if you plan to track the car.... and probably even if you don't
This is what you want if you do lines and for fluid I'd go ATF Blue.
Depending on how they are made, two piece rotors usually have an aluminum center hub or hat that joins the iron/steel friction ring with floating spacers.
The aluminum means the brakes can be lighter, and the floating ring allows the rotor to heat up and expand uniformly. If the rotor was solid iron, the rotor would have differential heating and expand at the edges while the centers were still cool. This leads to a dishing of the brake. Since this stress isn't there anymore, you don't have to make the rotor as beefy(heavy) to handle the flex. This in turns saves weight.
It also looks cool, cause you can paint your hats different colors and they don't flake off like on one piece deals.
Thanks, Zak!zaxrex wrote:Depending on how they are made, two piece rotors usually have an aluminum center hub or hat that joins the iron/steel friction ring with floating spacers.
W3RD! They are also available in different colors as well.zaxrex wrote:It also looks cool, cause you can paint your hats different colors and they don't flake off like on one piece deals.
lol, just got back to this thread.... but I see Zak has already handled it! w00t
