VF39 swap
NasbaRex
VF39 swap
Post by NasbaRex »
anyone know wher i can find a vf39 swap write up so i can have a reference guide while doing it?
and is a walbro 255 a needed supporting mod for an o6?
yummy displacement
04 PBM GTO
hotsam
Post by hotsam »
I'd search scoobymods.com, they tend to have plenty of write ups. Another option is to search the 2.5l forum over at NASIOC.
Outside of that, a turbo swap is a pretty common procedure that can be finished in a few hours with skilled hands and plain old hand tools. Even if you've only got one person around you who's done the process before, you'll be fine.
As far as supporting mods are concerned, the only thing you really "need" other than the bigger fuel pump is some sort of engine management system (COBB, UTEC, ECUTEK, etc.)
Although, if you're talking about a turbo swap I highly recommend an STi-sized TMIC and a turboback exhaust as well. That ought to put you right at 300hp/300tq at the wheels.
...and that is faaaast.
NasbaRex
Post by NasbaRex »
thanks guys....
i searched nasioc for awhile without finding much useful info...
i have an ebay TMIC lying around somewhere....
i have a catless TBE
and an AP
so im just short a vf39 and a fuel pump
yummy displacement
04 PBM GTO
How about injectors? What are the new 06 WRX rated at with an upgraded pump?
When are you going to do the turbo swap? I know that all of us have a good bit of things to do.... maybe we can organize another install day :)
Turbo swaps go pretty easily as long as you take your time. Make sure to put a hose clamp on the bottom oil return line as it has a habit of leaking!
Sabre wrote:How about injectors? What are the new 06 WRX rated at with an upgraded pump?
Teh 06's flow equal to teh JDM pinks used in the 02-05's. He's fine with them.
NasbaRex
Post by NasbaRex »
can u just pull the fuel pump relay and crank the motor over in order to prime the turbo with oul instead of doing all the crap that is in that wirte up?
yummy displacement
04 PBM GTO
hotsam
Post by hotsam »
Yep...you can do that.
Exactly what I do.. but in a different spot :) There is a green connector in the passenger foot well on the right. Pull it straight down and it will disable the pump.
Sabre wrote:Exactly what I do.. but in a different spot :) There is a green connector in the passenger foot well on the right. Pull it straight down and it will disable the pump.
Fuel.Pump.Relay.
It's just a connector in between ;) I thought the relay was in the same spot as all the others (in the engine compartment)
whatev... something like that. the box itself looks like a relay to me.
HA-------------IRS
