Quick question,
Getting ready to pick up a can of teh Black Satin for the DP and everything I've read in the forums talks about spraying it on. However, all of the pictures show a can of it that looks like it's something you spread on with a brush or something.
Am I looking at the right thing? The link I followed was http://www.caswellplating.com/aids/techline/.
Black Satin (spray or spread)
- Osiros
Yep, that's the one you want
I've always just brushed mine on with a disposable brush and then baked them in my grill... works like a charm
Couple of notes: Make sure to wear gloves and a mask. Get several brushes, BS will eat through the cheap ones after about 20 minutes...
- Osiros
The head from headers and a UP will definitely cook it, but for a DP throw it in your oven at as high as it will go for an hour. Make sure to put down aluminum foil so none of the BS gets on your oven...
Yes, it is that toxic
It contains lead and other nice things...
Yeah, so don't eat it.Sabre wrote:Yes, it is that toxicIt contains lead and other nice things...
I'm trying to think, when I did mine I just sprayed on a nice think coating, let it dry, then sprayed in all of the parts I missed. I wanted to do a second coating but I think the directions said not to so. However, when I look at my DP now it doesn't look like there's any Black Satin left on it.
Could it have all burned off?
