Fifteen years of experience has turned KLEEMANN into world market leader in Kompressor (Supercharger) technology for Mercedes-Benz engines. Now KLEEMANN introduces a new system developed for the M273 V8 engine range fitted in the current 450 and 500/550 model ranges.
Like the Kompressor system for the outgoing V8 engine range (M113) the new design integrates the inlet manifold, intercooler and Kompressor in one integral unit. A compact design that ensures factory-like fit looks and quality.
Kleemann Introduces the EMS (Kleemann Engine Management System)
Cutting edge engine management technology - Sporty engine characteristics The anti-clockwise rotating Roots type Kompressor is characterized by its unique ability to develop plenty of power at low boost pressure and this type of supercharger has proved its reliability and efficiency for many years. The new electronically controlled fuel injection and management system KLEEMANN EMS is on the other hand a technological break through.
The fuel injection and management system allows boost pressure to vary from 0,3 bar to 0,70 bar (4psi to 10psi) as the engine rotates up the rev scale. The electronically controlled, varying boost pressure ensures progressive and sporty engine characteristics known from naturally aspirated high performance engines. Increase in rpm results increase in increased power output all the way to up to the rev limiter. Furthermore the system ensures an effect curve without any bumps or valleys. The EMS reduces boost pressure thus power output a fraction of a second before gearshifts to ensure smooth and gentle shifts.
Punch from Idle
Like the earlier generations of KLEEMANN Kompressor solutions the new system still ensures plenty of torque from low revs thus a car fitted with the new system will have plenty of punch from rev levels just above idle. 90% of torque is present at 2000 rpm.
Safe, Durable, Reliable
The low boost pressure of just 0,30 - 0,70 bar makes the system safe and provides long-term durability for the engine. To further improve the safety aspect the EMS features a safety mode constantly monitoring the fuel - boost pressure ratio ensuring that the engine cannot run lean thus suffer damage to the engine. In other words the boost pressure and amount of fuel injected to the engine will always comply. Even if the car is driven in an area of high altitude (less oxygen, low pressure) and down to sea level boost pressure and fuel supply adjusts automatically to protect the engine from running lean.
Will be interesting to see what that does to some of those nice NA power plants!
Not suprising, their power output on a 5.5 liter is similar to the last generation supercharged AMG 55 motor. It trades a bit of torque (34) for a bit more hp (31).
Example form their site:
engine: 5.5 V8
stock hp: 354/360/367
stock torque: 377/389/392
Kleenman hp: 500
Kleenman torque: 482
AMG E55:
hp: 469
torque: 516
There was a write-up on the Kleemann C55k S8 (an AMG C55 with the Kleenman Kompressor, plus cams, ECU and exhaust) it claimed 600 Hp and 560 lb/ft of torque and ran 3.7 seconds from 0-60 mph and 12.5 seconds from 0-125 mph. It takes an E55 12.5 seconds to hit 116 mph. You can bet that's a sub 12 second car.
And if you want one there's a used one for sale at Kleenman's site in Colorado for $57,000 with only 4,900 miles on it.
