Can anyone help shed a little light on what these things actually do and what gains and/ or losses I can expect iffing I should get the BOV also?
Blow off Valve
Blow off Valve
I need a lesson. The guy who I'm getting the UTEC from is also offering a TurboXS RFL blow off valve for an additional 175 bucks. Now I don't much about blow off valves beyond that they're supposed to help the turbo (in some way), in the wrong setup they can compromise driveability or cause turbo lag, and the noise they make can attract cops.
NO. DON'T GET ONE. RUN AWAY FROM THE BLOW OFF VALVE. IT'S TOTAL CRAP. LEAN CONDITION AFTER SHIFT FTMFL.
Yea, they suck.
Yea, they suck.
complacent wrote:NO. DON'T GET ONE. RUN AWAY FROM THE BLOW OFF VALVE. IT'S TOTAL CRAP. LEAN CONDITION AFTER SHIFT FTMFL.
Yea, they suck.
^^Wise words, Chuck!
On a more technical note:
The stock BOV is good to around 21PSI, after that it starts to leak. The stock turbo (VF39 in your case) is WAY out of it's efficiency range at those boost levels, so I doubt you'll ever see them unless it's by mistake or with water injection. When you upgrade your turbo, if you plan on running more than 21PSI, then you might consider upgrading the BOV. By that time, you'll probably have switched over to a FMIC anyway
