Noise cancellation...
I came across this article which describes how to build your own set of noise cancelling headphones.
The circuit is suprisingly simple, so in a couple of hours, you could have your own set!
Funny man... It's not greek to all of us....
i wouldn't even know where to begin.
really.
chicken n waffles wrote:i wouldn't even know where to begin.
really.
With one of hte Ops amps probably... That's one of the triangle looking thingys
:crazy: Fire hot, tree pretty.
I could actually build these at work! :D
So the first part (left half) we have two channels (stereo) each with two filtering amps. Those take an audio jack as an input, and send the output to a switch and then thru a pot. Then we have a second set of amps, with no filtering, that look to be set up as straight amps. These take an audio jack as an input, but send them thru a pot first, and then the output is a jack... so basically the first part is generating your negative signal from your noise (which comes from a microphone), with a pot for adjusting the amount of cancellation. Second part takes that, adds it to the volume-adjustable audio input and power outputs it to the headphones...
See, program managers can read circuit diagrams. :)
Libra Monkee wrote::crazy: Fire hot, tree pretty.
:rolllaugh: :rolllaugh: :rolllaugh:
I use this for my noise canceling headset!
:lol2:
