FS in VA: '04 STi TMIC
SOLD!!!!
- GeneralGrievous
- GeneralGrievous
- GeneralGrievous
I can hold it for you. When will you have the money?GeneralGrievous wrote:![]()
I'll take it but when do you need the money by??
- GeneralGrievous
Okay just ignore the PM I just sent you...the 7th is fine. I will hold it until then.GeneralGrievous wrote:By the 7th.... if thats not too much of a hassle (and if you dont have too many offers on NABISCO...
Can you feel the DCAWD love?!?!?!
- GeneralGrievous
I can give a hand w/ the install. What turbo are you running?GeneralGrievous wrote:Thanks Will... you DA MAN. Now I just gotta get my hand right and make an install day....
- GeneralGrievous
Are you talking about a water sprayer for the TMIC? If so, I have no idea. But as far as hooking up the STI TMIC to your TD04, you may have a problem using the stock STi elbow hose. Might need to a) reuse your stock Y-pipe and elbow or b) just get a new elbow hose and trim it to fit...if it was me, I would just do the second.GeneralGrievous wrote:stock sir... am I going to have a problem with the sprayer since its going on my wrx?
Who knows what the future holds but it would be awhile till i hooked one up..
- GeneralGrievous
I can help you modify the stock splitter to work w/ the new TMIC.GeneralGrievous wrote:Ah ok.... just good to know I have stuff to do once work slows down![]()
Is the stock WRX y too short or is the diameter different than that of the stock turbo?
Or you can grab a $129 GT Spec splitter...but modification is cheaper and it works better.
- GeneralGrievous
^^^ Hmm, who does he mean...
How's July 9th at my place for everyone?
Works for me but I will be there late as usual from coming back from PA.sabre wrote:^^^ Hmm, who does he mean...
I will be working on my custom splitter this week and next. Looks like I will be fabbing it by hand instead of AutoCad. I will start w/ cardboard and then finish w/ aluminum and rivets...and paint.GeneralGrievous wrote:Me likey the cheaper AND better.... But I'm sure you got alot going on, hopefully we can hook it up on an install day (hint hint to The Powers That Be)
- GeneralGrievous
