A good WRX stock turbo thread
http://forums.nasioc.com/forums/showthread.php?t=981689
TD04 yadda yadda yadda, compressor maps, yaddya yadda, compared with VF-22...
Now I don't feel so guilty about running 20 PSI on my 30...
Just a taste
ok, 20PSI~=1.4 bar. Wouldn't you want to be between 1.6-1.8 for the sweet spot? Ug, I must be reading this wrong...
Pressure ratio is the Y-axis. Unitless.
For a rough estimate thought, multiply those numbers by 15 to get near the PSI rating...
EDIT
i mean subtract 1 and then multiply it by 15
hotsam
Re: A good WRX stock turbo thread
Post by hotsam »
zaxrex wrote:[url]
I've been doing it for like 4 years.
Compressor maps are a very tricky thing to base a real-world decision on. We don't know what is generating the curves (what engine/displacement, what ambient temp, ect.) and we'll never know the differences between two different manufactures.
I have known people who have run crazy high boost on TD04 turbos, some in excess of 22psi.
Zak I don't think you should have any fears of running your vf30 at 20 psi. 25psi might be a bit over the top however, even with alky injection.
My boost gauge only goes to 20 :lol:
