Hey all,
so I'm overboosting on the track to the point i hit fuel cut. So I'm trying to figure out what will help it. I can just turn down the boost, but then whats the point if I'm running less boost? So I'm trying to think of things i can do to fix the problem, and a catted DP might help.
anyone have one i can barrow?
-Ross
anyone have a catted 3" DP i can barrow?
- spazegun2213
- teh Spaz
Gone But not forgotten
Yeah, I am having problems w/ my tranny from overboosting so can I borrow somebody's STi 6 spd for a little while
...but seriously Ross, what DP are you running?
- spazegun2213
- teh Spaz
rofl, thanks will.sirwilliam wrote:Yeah, I am having problems w/ my tranny from overboosting so can I borrow somebody's STi 6 spd for a little while
i have julians old godspeed.
Turn the boost down son, it will save you in the long run...
- spazegun2213
- teh Spaz
sad part is, then I'll be jsut over stocksabre wrote:Turn the boost down son, it will save you in the long run...
If you go into 3rd and hold down the gas, what boost are you running? I'm running 17.5spazegun2213 wrote:sad part is, then I'll be jsut over stocksabre wrote:Turn the boost down son, it will save you in the long run...I'm not even running 17psi right now.
I can't remember what stock STi boost is...b/c that is what I am running (stock STi map) until I get my clutch replaced w/ the exedy stage 1.spazegun2213 wrote:sad part is, then I'll be jsut over stocksabre wrote:Turn the boost down son, it will save you in the long run...I'm not even running 17psi right now.
I used to be 18PSI at 3K tapering to 14PSI at redline (think it is set to 7.5K)
- spazegun2213
- teh Spaz
should be just under 17 for me.sabre wrote:If you go into 3rd and hold down the gas, what boost are you running? I'm running 17.5spazegun2213 wrote:sad part is, then I'll be jsut over stocksabre wrote:Turn the boost down son, it will save you in the long run...I'm not even running 17psi right now.
will, i think stock is 15.5?
