IPT - Performance Valve Body Kits
I've seen Level 10 mentioned a bunch of times, but mostly in a negative light.
That certainly is what I have read. Every long term case I have researched indicates the front diff/clutch assembly is pretty robust and isn't really the issue. My biggest issue is the cost/benefit analysis. It is a very pricey piece of kit. I'm not certain I could justify it on a 5 year old car, let alone a 10+ one.Sabre wrote:It's usually the rear that ends up going, isn't it?
the 4.11 or the 4.44?drwrx wrote:Sadly, my rear diff is starting to 'clunk' under hard acceleration, so I see some cash outlay coming in the future.
Klunk Killer bushings.drwrx wrote:That certainly is what I have read. Every long term case I have researched indicates the front diff/clutch assembly is pretty robust and isn't really the issue. My biggest issue is the cost/benefit analysis. It is a very pricey piece of kit. I'm not certain I could justify it on a 5 year old car, let alone a 10+ one.Sabre wrote:It's usually the rear that ends up going, isn't it?
