Raven wrote:The advantages of DI is really only for steady state cruising where they run super lean. At full power they perform about the same as more traditional injector setups. DI is a have your cake and eat it too thing, fuel economy and power.
DI helps enormously in turbo charged applications because you can precisely control when fuel is injected. This helps you prevent knock, lets you run higher timing etc. etc.
