ARC welding is cool.
Plasma torches are cool.
Handheld plasma guns are awesome.
Ditching the pressurized tanks, hazardous fumes, and the I'mma gonna kill you amperage to run off of water and alcohol?
Priceless.
I present to you the Multiplaz 3500!
Multiplaz 3500 can weld, solder, braze, harden, and cleanse metals including steel, aluminum, copper, cast iron, bronze and other metals.
Multiplaz 3500 can cut any metal, including high-alloy and stainless steel that can not be cut with oxygen cutting. Cutting ceramic tiles, quartz glass, bricks, concrete and other inflammable materials is another unique feature of the Multiplaz 3500.
The Multiplaz 3500 can concentrate the plasma stream into a small diameter jet like a laser.
This feature allows you to melt even thick 12 inch (300 mm) metal to the depth of up to 7/16 inch (10 mm), weld thin plates of 1/64 inch (0.5 mm) to thick ones, surfacing metal on bulk parts and solder tool steels.
Daddy wants.
http://www.youtube.com/watch?v=Npg3Mn2x450[/video]
You had me at plasma jet.
