Acoustic Stealth Technology Created
BBC
Such acoustic cloaking was proposed theoretically in 2008 but has only this year been put into practice.
Described in Physical Review Letters, the approach borrows many ideas from attempts to "cloak" objects from light.
It uses simple plastic sheets with arrays of holes, and could be put to use in making ships invisible to sonar or in acoustic design of concert halls.
Much research has been undertaken toward creating Harry Potter-style "invisibility cloaks" since the feasibility of the idea was first put forward in 2006.
Those approaches are mostly based on so-called metamaterials, man-made materials with properties that do not occur in nature. The metamaterials are designed such that they force light waves to travel around an object; to an observer, it is as if the object were not there.
But researchers quickly found out that the mathematics behind bending these light waves, called transformation optics, could also be applied to sound waves.
"Fundamentally, in terms of hiding objects, it's the same - how anything is sensed is with some kind of wave and you either hear or see the effect of it," said Steven Cummer of Duke University. "But when it comes to building the materials, things are very different between acoustics and electromagnetics.
Pretty cool tech. Always interesting when Science Fiction influences real life science!
Re: Acoustic Stealth Technology Created
just the concept is mind-boggling, let alone the actual implementation. very rad.
the tin foil hat: it does nothing! :eek:
I concur.
Very, very...
