Wow, I'm amazed.... Anyone actually do any tests to see if the voltage and such are the same?
12VDC is 12VDC, and the nipples are the biggest restiction, but since you are not going anywhere near the 8CFM in sending the pressure signal, there is no appreciable pressure loss through the system.
Ah, I didn't know the Perrin accepted 12VDC signals
