2012 Infiniti M Hybrid
Posted: Tue Aug 03, 2010 8:43 am
ARTICLE LINKY
Yokohama, Japan—Today we got an early taste of what to expect from Infiniti in March of 2011. The 2012 M Hybrid is first vehicle to showcase Infiniti’s new full parallel hybrid system. This system utilizes an updated version of the 3.5-liter VQ35DE V-6 in conjunction with 50-kW motor (67-hp) that’s powered by Nissan’s proprietary 1.3-kWh lithium battery stack. When combined, the system is claimed to produce about 369 bhp, which is a 39 bhp gain over the M37.
If you’ve never been a fan of those motorboating CVTs, as most enthusiasts aren’t, you’ll be thrilled to know that Infiniti has chosen a way to weave its terrific 7-speed transmission into the powertrain. This involves the use of two clutches, one between the engine and electric motor (which then mates directly to the transmission without a torque converter), and one after the transmission before the driveshaft. The former clutch is a dry clutch which is responsible for decoupling the gasoline engine from the rest of the powertrain. This happens under pure electric driving scenarios (which we’re told can occur at speeds up to 100 km/h or 62 mph), or during coasting when the system can best utilize the car’s kinetic energy for regenerative braking rather than engine braking. Clutch 2 is a wet clutch that’s used to temper any sort of drivetrain dissonance, but will also decouple at a standstill in case the engine needs to turn the electric motor (and thus transmission) to recharge the battery. (Porsche uses a similar configuration on its Cayenne Hybrid.)
All things considered, the entire Hybrid system is quite tidy, adding a total of 264 lb. to the weight of an M37, which puts it right in between an M56 and the all-wheel-drive M56x. Although you don’t get quite the punch of that vicious V-8, the Hybrid definitely scoots with lively urgency while delivering its synergistic thrust with a smoothness I’ve never before felt from a VQ. The weight is somewhat noticeable, but with both lead-acid and lithium batteries mounted aft of the rear passenger seatback, it’s in the right place and therefore not overly detrimental to handling. Both the steering and braking systems in the M Hybrid are now electrically assisted and contribute to the M’s efficiency, though extraordinary measures were taken to ensure that the natural feel and response of these critical driver interfaces were preserved.
Unfortunately Infiniti didn’t have any hard fuel economy numbers for us during this early drive. However, the company speculates (based on preliminary real-world testing) that the M’s dual-clutch hybrid system will offer fuel economy on par with a 1.8-liter inline-4 compact in both city and highway driving.
