pwnat
Posted: Mon Apr 26, 2010 5:03 pm
Site
pwnat, pronounced "poe-nat", is a tool that allows any number of clients behind NATs to communicate with a server behind a separate NAT with *no* port forwarding and *no* DMZ setup on any routers in order to directly communicate with each other. The server does not need to know anything about the clients trying to connect.
Simply put, this is a proxy server that works behind a NAT, even when the client is behind a NAT, without any 3rd party.
There is no middle man, no proxy, no 3rd party, no UPnP/STUN/ICE required, no spoofing, and no DNS tricks.
More importantly, the client can then connect to any host or port on any remote host or to a fixed host and port decided by the server.
pwnat is based off of the UDP tunneling software by Daniel Meekins, udptunnel, and my original chownat.
Yes, it does work :twisted:
Re: pwnat
Posted: Mon Apr 26, 2010 6:55 pm
interesting... sounds like nerd stuff though. :wink:
Re: pwnat
Posted: Mon Apr 26, 2010 7:03 pm
Eh, since it wasn't... let's say official type stuff, I put it in OT, but I suppose this is as good a home :)
Re: pwnat
Posted: Mon Apr 26, 2010 10:19 pm
by schvin
this is an interesting technique...
Re: pwnat
Posted: Thu Apr 29, 2010 2:35 pm
does anyone else here think it looks kind of messy with all that UDP traffic? especially with the udp keep alive, i'd think it would be awful easy to spot.
or was the purpose to prove that it could be done?
Re: pwnat
Posted: Thu Apr 29, 2010 3:05 pm
by scheherazade
You can spot TCP just as easily.
Just swap your switch for a hub, and run wire shark. Gives you everything.
What's great about pwnat is that it's so simple.
The gist of it : send crap out, so whatever comes in the NAT thinks is a reply
I can see this being used to help someone behind a NAT run a server.
Security wise, it's pretty benign.
-scheherazade
Re: pwnat
Posted: Thu Apr 29, 2010 6:47 pm
complacent wrote:does anyone else here think it looks kind of messy with all that UDP traffic? especially with the udp keep alive, i'd think it would be awful easy to spot.
Agreed, this version is messy, but imagine a very targeted version that isn't so messy and you'll see how evil it really is.
