Window Squeak Solved!
Posted: Mon Sep 07, 2009 11:50 am
So my front passenger window has been making a horrendous squealing noise every now and then as it's being lowered. I finally got fed up and did some searching for a solution. I should have known it'd be an easy fix.
Got some silicone spray lubricant (this brand). Cleaned the window first, lowered it, sprayed the lubricant into the vertical piece of rubber on the front of the door, and tested. No squealing!
So if anyone else is having this problem - now you know what to do. That's my PSA for the week.
