Emissions Testing
Posted: Tue Oct 04, 2005 12:45 pm
this was originally posted by Mach V Dan on NASIOC:
having finally gotten my UP/DP in working order I'm not enjoying the prospect of swapping pipes every 2 years. I just wanted to get this discussion started [again] and see what we can come up with. any shops we can trust to run a test and see what happens without reporting us or some such nonsense? I just wonder if the AccessPort will cover for me if I take out the resistor?Unfortunately, this is not the case. The state inspection system requires that the car has performed its own steady-state cruise cat test, which it does every few hours during highway type driving. With the resistor CEL fix, although your CEL won't come on, the car will never complete that test cycle. And so when the inspection station goes to plug in the OBD II tester thing, they'll tell you you need to go back out and drive around some more, then come back.
