FIOS: 75% FTW, 25% FTL
Posted: Wed Apr 30, 2008 8:27 am
FIOS high speed internet access is great... when it works. we've had a bear of a time keeping our connection up at Casa de Turbo. I think it's the crappy fiber link/router that they make you use that makes the service is about as stable as a Hollywood marriage. it will work for days, then it will but up and down like a yo-yo. the WAP works, sometimes. the hard wired ports work, sometimes. occasionally the WAP will be up and my wired connection will be down. other times it's the reverse.
I hate to say it but the cable modem from Comcrap was more reliable.
Re: FIOS: 75% FTW, 25% FTL
Posted: Wed Apr 30, 2008 9:40 am
by chicken n waffles
it's not the service, it's the shitty actiontec router they gave us. certain programs easily crash it. the 2 that i've nailed down are the adobe updater and refreshing full server lists on steam. kills it instantly. there are others but those 2 kill it for sure. i tried setting up the 2nd router they gave us but it couldn't establish a connection out of the box, and doing a factory reset does nothing. i might just buy an aftermarket 802.11n router and be done with it if i can find one for a good price.
Posted: Wed Apr 30, 2008 10:32 am
by WRXWagon2112
I've found that our FiOS router/modem needs to be power-cycled more often than the Comcast modem we had previously. However, the longer we've had FiOS the longer we've been able to go between cycling the power.
Hang in there little campers, it'll get better!
Posted: Wed Apr 30, 2008 11:20 am
WRXWagon2112 wrote:Hang in there little campers, it'll get better!
actually it's gotten worse as time goes on.
Posted: Wed Apr 30, 2008 12:07 pm
by Libra Monkee
Which is why when I got FiOS the first thing I did was took the old cheapo router that they gave us and kicked it into the river. Since I've installed my own router I haven't had any p0rblems.
Posted: Wed Apr 30, 2008 2:07 pm
I knew we kept Monkee around for a reason.
Posted: Wed Apr 30, 2008 2:27 pm
i thought it was for the funny shirts and interesting belt buckles
Posted: Wed Apr 30, 2008 4:03 pm
THe Verizon Fios supplied wireless router is a POS! My father's and a friend's at work both kicked the bucket. Just replace it w/ a nice reliable Linksys and call it a day. Don't forget to renew w/ ipconfig.
FIOS > Cable > DSL > Dial up > courier pigeon > smoke signals
Posted: Sun May 11, 2008 2:48 pm
by ElZorro
We had alot of problems with the FIOS router out in Leesburg. What it ended up being was a bad batch of power adapters, the tech said that most of the ones they installed in our neighborhood were bad (causing weird lock ups, requiring power cycling, and apparent lockups when accessing certain features), and that there were still a bunch of bad ones being installed because some techs were not pulling the inventory from their trucks. Recommend you call Verizon and get someone out to look at it.
Posted: Mon May 12, 2008 7:48 am
Save your time and money...just replace it w/ a reliable one that works!
Posted: Tue May 20, 2008 4:57 pm
well, since it's a modem and a router all in one, we can't just replace it.
but we CAN buy a linksys 802.11g router, configure fios' router to be nothing more than a connection bridge to the linksys, and enjoy the benefits of a normal size nat table (actiontec = 1kb nat table) and increased wireless signal range.
f***er won't crash even when subjecting it to "stress tests."
Posted: Tue May 20, 2008 8:38 pm
FIOS + C&W =
