Diesel Boxer Engine Coming to Europe. Soon to U.S.
Posted: Thu Jan 24, 2008 11:35 am
by WRXWagon2112
According to
Car & Driver.com, Subaru will debut the world's first production boxer diesel engine in European versions of the 2008 Subaru Legacy and Outback beginning in March.
They claim that it
will be coming to the U.S. but they're not sure which specific models will use it - though they say the Legacy, Outback, and Forester are likely candidates.
So what say you all? Anyone willing to take a diesel Subaru?
Posted: Thu Jan 24, 2008 11:45 am
Yes, I'll take one please...
By the time it makes it's way over here, I will have the biodiesel reaction process tuned to perfection.
If the Germans can make a clean quiet diesel, then the Japanese should have no problem.
Posted: Thu Jan 24, 2008 11:46 am
by WRXWagon2112
Beware though, it'll likely be mated to an automatic when it arrives over here.
Hmmm... I know I have
seen this
before
I'm ALL for it... Not much for HP, but diesel's produce huge amounts of torque!
Posted: Thu Jan 24, 2008 11:49 am
by WRXWagon2112
Yeah, I quickly glanced at the thread titles and didn't see schvin's. Yours was titled "An announcement...". What does that tell me?
Didn't feel like using the search function, either. My bad.
Posted: Thu Jan 31, 2008 4:06 pm
by GaToR
Edmunds.com wrote:We're driving the 2008 Subaru Legacy Boxer Diesel in Malaga, Spain, but we might as well be in Southern California.
Everything looks like Southern California already, right down to the Spanish on the street signs. And while you might think of the distinctive clatter of diesel from beneath the Legacy's hood as the signature sound of European traffic these days, we promise you that it will be heard on the streets of Orange County soon enough.
This 2008 Subaru Legacy Boxer Diesel is a European model meant to go on sale this spring, but we think it's surely coming to America. A wave of diesel technology is headed toward the United States, and Subaru clearly wants to be riding the crest.
10 Years in the Making
Kenichi Yamamoto, the man in charge of the development of this car, makes no secret of Subaru's lofty ambitions for the 2008 Subaru Legacy Boxer Diesel, which features the world's first horizontally opposed diesel engine for passenger cars.
"The benchmark cars were the BMW 320d, the Audi A4 and the Honda Accord turbodiesel," he says. Yamamoto admits that research started on the project nine years ago, but it was impossible at that stage to build a business case for the engine. "Now the situation is different," he notes. "In Europe we need to reduce our carbon-dioxide emissions; we cannot survive without diesel."
The new engine was given the green light for production just two years ago, prompting an engineering scramble to turn a promising concept into a reality. It was a tough challenge, but Subaru has not skimped on the technology.
Practical Reengineering
The basic lump is familiar, a turbocharged, DOHC 1,998cc horizontally opposed four-cylinder engine. To convert this architecture to diesel, the first significant change is a dramatic 6mm reduction in the cylinder bore and an 11mm increase in the length of the stroke. Now the bore and stroke are symmetrical at 86.0mm. One of the results is a much shorter crankshaft that measures 13.9 inches, some 2.4 inches shorter than before.
To minimize weight, the block as well as the cylinder heads are made from aluminum. Subaru tells us that the structural integrity of the boxer configuration helps make this measure possible. As with almost every European turbodiesel, the Subaru employs common-rail technology for the new engine. The turbocharger is mounted below the engine and connected directly to the catalytic converter, an installation that's becoming more common in all kinds of engines because it promotes quicker light-off for the catalyst.
The power figures are impressive. The boxer diesel produces 148 horsepower at 3,600 rpm and 258 pound-feet of torque at just 1,800 rpm. The engine is capable of 60.5 mpg. This compares with the 320d's turbocharged 2.0-liter inline-4 diesel that produces 174 hp and 271 lb-ft of torque, while the Honda Accord's turbocharged, 2.2-liter inline-4 diesel delivers 138 hp and 251 lb-ft of torque. Meanwhile, the gasoline version of Subaru's 2.0-liter four-cylinder boxer also manages 148 hp, but just 144 lb-ft of torque.
Driving in the Real World
The new engine will appear first in the 2008 Subaru Legacy Boxer Diesel and the 2008 Subaru Outback Boxer Diesel, both of which are scheduled to be introduced in Europe this spring. The badge on the Legacy sedan's trunk reads, "Boxer Diesel" and the car is also set apart by the scoop on the hood that directs air to the air-to-air intercooler on top of the engine. Prod the starter button and you'll hear an unmistakable diesel rattle. It's not loud or especially intrusive, but it's there all the same.
Move away and the rattle subsides immediately. Subaru has increased the quantity of acoustic insulation in this car, but there can still be no denying that this is an exceptionally (and unexpectedly) quiet engine, an aspect of the horizontally opposed configuration, Subaru claims. At full throttle, you can hear the characteristic growl of a Subaru boxer, although it's deeper than the gasoline equivalent. Really, you have to listen hard for it, and the engine noise at highway speed is notable only by its absence.
The engine pulls cleanly and easily from as low as 1,700 rpm, although its best work is done by the time the tach needle reaches 4,000 rpm. The power flexibility through the midrange is impressive. In top gear, the diesel takes 23.4 seconds to accelerate from 50 to 100 mph, a veritable sprint compared with the 37.0 seconds it takes a Legacy with a normally aspirated 2.0-liter gasoline engine to accomplish the same feat.
Our only criticism of the Legacy Boxer Diesel has to do with the transmission. First, the shift lever is farther forward than before. But more important, the wide-ratio five-speed doesn't seem to make the best use of the wide power band, and surprisingly enough a six-speed would be a better match. Yamamoto admits that a six-speeder is under development and will be ready by the end of the year, together with an automatic version.
The Business Case for Diesel
At present, Subaru's new diesel engine is destined only for Europe, but Subaru is taking a wait-and-see approach to its introduction in Japan and the U.S. At present, the engine will not meet California's stringent air emissions regulations. "We would only introduce the car in the U.S. if it was legal in every state," says Yamamoto. "Meeting the California legislation is very hard and very expensive. We are researching it, but there is no timetable." Subaru estimates that fitting the particulate filter needed to make the engine fully compliant would add around $1,500 to the price of the car.
Nevertheless, Hirofumi Senoo, the general manager of Subaru's European test center tells us, "Diesel is the main focus for the U.S. market. It has more potential than hybrid gasoline engines because hybrids are only good for the city." Subaru will let others take the lead in the introduction of diesel to the U.S., but will be ready to strike if the market becomes receptive.
Only the Beginning
This engine is really only the start of Subaru's diesel strategy. In addition to the 2008 Legacy Boxer Diesel and 2008 Outback Boxer Diesel, the Impreza will feature the new engine toward the end of the year.
And, having proven the technology, Subaru is confident that it can produce versions with as much as 161 hp without any risk to its durability, although such a power output would increase fuel consumption and air emissions. There is even talk of an STI version or even a rally special. "It is my personal opinion that it would be good to see a motorsport version," Senoo says. "A WRC engine has lots of torque but not much power."
Europe has been deluged with a wide range of brilliant turbodiesels in recent years. BMW in particular has led the way with the development of diesels that are quieter, more frugal, less polluting and, in most cases, more powerful than their gasoline equivalents. Subaru is late to the party but its entrance is impressive.
[Once on the move, this is one of the most refined diesels on the market today. This is a boxer that can punch above its weight.
More news on that front
Aluminum block is rare on diesels. And the boxer seems to solve the problems associated with massive sidewall stress.
60.5 mpg in a midsize. That's 100% more than what you'd expect from an N/A Legacy and 50% more than any midsize hybrid. Throw a 6-speed in a diesel boxer and send it my way!
Posted: Thu Jan 31, 2008 4:28 pm
This is all I needed to read:
The power figures are impressive. The boxer diesel produces 148 horsepower at 3,600 rpm and 258 pound-feet of torque at just 1,800 rpm. The engine is capable of 60.5 mpg. At full throttle, you can hear the characteristic growl of a Subaru boxer, although it's deeper than the gasoline equivalent. Really, you have to listen hard for it, and the engine noise at highway speed is notable only by its absence.
Only the Beginning
Sign me up!!! The new mounting point of the turbo has me VERY interested!
Posted: Thu Jan 31, 2008 4:55 pm
Sabre wrote:This is all I needed to read:
Only the Beginning
Oh wow! That almost sounds too good to be true!
Posted: Thu Jan 31, 2008 5:15 pm
Posted: Fri Feb 01, 2008 5:15 pm
by ElZorro
I'd rock it. I've been thinking about my next ride (Forester has 80K miles on it now), and this might be the right timing.
Re: Diesel Boxer Engine Coming to Europe. Soon to U.S.
Posted: Fri Sep 04, 2009 10:22 am
by schvin
Posted: Tue Sep 15, 2009 9:24 am
Legacy + diesel + LHD =
faptastic in Japanese, of course.
how it works
Posted: Thu Oct 28, 2010 7:36 pm
Subaru diesel is
tricky
Jalopnik wrote:...Subie's also shifted to a fracture split bearing for the crank end of the connecting rods. What does that mean? Well, the connecting rod is forged as one unit, complete with holes at the crank bore and wrist pin ends. Machining operations clean up the surfaces and create the threaded holes for the bearing cap bolts, then the rod is scored along the split plane of the crank end bearing with a high powered laser. An expanding mandrel is then inserted and breaks the end of the rod in a controlled manner inline with that laser etching. The rough surface remains and acts to positively locate the connecting rod cap in space without any fancy machining.
Damn, I had to read that thing like three times to fully understand what they were talking about.
But seriously, they had me at high powered lasers.
Posted: Fri Oct 29, 2010 9:31 am
That's a pretty interesting approach!
BTW, this I LOVED and have been waiting for forever!
For a little fresh air to go with that fuel, the turbo is a variable nozzle geometry unit
Posted: Tue Nov 02, 2010 11:15 am
by Raven
zaxrex wrote:Damn, I had to read that thing like three times to fully understand what they were talking about.
Chevy has been manufacturing rods like this for years. It's hardly a new process.
Posted: Tue Nov 02, 2010 1:03 pm
Really? I thought most of their rods were powdered metal. What engines used forged rods made by laser fracturing?
Oh, and Chevrolet never made a diesel engine.
Posted: Tue Nov 02, 2010 3:25 pm
by Raven
zaxrex wrote:Really? I thought most of their rods were powdered metal. What engines used forged rods made by laser fracturing?
They are powdered metal, but also forged I believe. But I was talking about the cracking of the big end rod caps. They've been doing that since they started with the powdered metal rods. It's nothing fancy really, just a way to make things cheaper. The small block chevy V8 is the master of doing good designs on the cheap.
