what the hell am i thinking?
Posted: Sun Aug 05, 2007 2:32 am
by WANGAN_X
I need to get rid of the GTO... to damned expensive, i though about buying a used car like a beater, nope not gonna work, so i need to get something cheap easy to mod, and reliable, also cheap to run
so... on that note, I am turning 90000* and must be dizzy, because, I have decided to buy a Honda Fit...
Posted: Sun Aug 05, 2007 1:00 pm
Well, Muegen or whatever they are has a broad line of aftermarket items for the Fit. The platform responds quite well to bolt-ons, from what I have seen in print.
Good luck
Posted: Sun Aug 05, 2007 1:25 pm
by thermobox
the fit is the sh1t. they have an awd version in japan. they do respond well to mods. and you can do a k series motor swap if your feelin frisky
Posted: Sun Aug 05, 2007 3:32 pm
by WANGAN_X
well the k series swap has not been done on this side of the pond and Mugen even said that it completely throws off the balance of the car
there are a crapload of mods out already, mostly chassis stiffners some performance, but supposedly even with a turbo swap your only looking at 200whp most. I was thinking JR SC over turbo because i plan to use this as a daily and a race car but maybe if the turbo is small enough it won't be an issue
Posted: Sun Aug 05, 2007 3:44 pm
by thermobox
Posted: Sun Aug 05, 2007 10:51 pm
by WANGAN_X
like i said... its nice and all, but, even mugen said handling is compromised by swapping in the k20 too much extra weight
Posted: Mon Aug 06, 2007 10:57 am
That looks like quite a bit of work... nevermind maintaining the motor/trans.
"I need to change my trans gasket and the exhaust manifold gasket"
"drop off your car, leave it for a week, it'll be $1500."
"$1500?!? WTF??!"
"We have to drop your engine out of the bottom of the car to reach them. "
"Oh...
Posted: Mon Aug 06, 2007 3:52 pm
The Fit and the xA I'd expect to be good little cars. Don't worry about leaving the goat, you'll have that speed back soon with either of the above
Posted: Mon Aug 06, 2007 10:49 pm
by WANGAN_X
well... i decided against the fit, after a test drive, for small reasons, which i was told are standard honda issues. no dead pedal, pedal placement, its awfully heavy for as tiny as it is
Posted: Tue Aug 07, 2007 2:11 pm
by Phibs
Good choice. Was gonna buy you 5lbs of rice.
Posted: Tue Aug 07, 2007 10:54 pm
by WANGAN_X
yeah even though the goat is spensive, it is a better platform stock, i find it funny reading about how some of em get worse mileage then i get in the goat right now i avg about 24-25mpg, i read posts about them only gettin 19-21 mpg...
so my engine being 4x the size is more efficient especially being nearly twice the weight
lawl... also, i am looking at a nice lil TT kit and a light cam, should be enough for 6**whp
also getting another job possibly, which will help my habit
