Cheap laptop
Cheap laptop
I'm throwing this out as a heads-up. If anyone comes across a cheap, and I mean cheap, laptop let me know. I'm going to be using it for tuning.
Well I've done it in the past without a problem. Just make sure it comes with an install disk unless your going to put your own OS on it. Oh! Also, use something like DBANor BCwipePDas soon you get it regardless of where you get it from just clear off whatever it's previous owner did to it.drwrx wrote:The craigslist post is already removed.
Laptops are one of the few things I will not get used off ebay.
I might just be paranoid, but I'm just a bit gun shy when it comes to that.
Yeah gonna try!
$270
# Processor Type: Intel Centrino
# CPU Speed: 1.6GHZ
# Num of CPU: 1
# RAM (MB): 512
# Hard Drive Capacity: 60.0GB
# CD Type: CD-RW/DVD-ROM
# Rem Media: None
# NIC: FAST-Eth/802.11b
# Modem: 56K
# Screen Size: 14.0 inches
# Screen Type: ActiveMatrix TFT Color
# Ports: 1 Parallel, 1 PCMCIA, 1 RJ-11, 1 RJ-45, 1 Serial, 1 VGA, 2 USB, AUDIO, IR, S-Video OUT
# Operating System: None
# Notes: SCRATCHES ON CASE
Cheapest spec'd one is $255 right now.
And like $50 shipping. Helps if more than one are ordered b/c shipping is not $50 for each item.
$270
# CPU Speed: 1.6GHZ
# Num of CPU: 1
# RAM (MB): 512
# Rem Media: None
# Modem: 56K
(note: these are laptops that have been chucked around by aol engineers for two years)drwrx wrote:That's exactly what I'm looking for!Phibs wrote: I can get you a decent modern used laptop from our work surplus for around 260 bux. Lemme know.
Are you coming to the meet on tuesday? If so, we can talk then.
Probably a little tardy to the party on this one, but back at Christmas I had luck finding refurbished Thinkpads for around $300.
http://saveateagle.resultspage.com/sear ... &view=grid
Or if that doesn't work, just do http://www.saveateagle.com/
www.austintech2000.com
They are in Sterling, VA a block away from MachV and have good prices. Give them a call.
http://www.notebookreview.com/default.asp?newsID=3996
Best Buy is selling a brand new laptop for $299.
