VF39 swap
Posted: Thu May 10, 2007 8:59 am
by NasbaRex
anyone know wher i can find a vf39 swap write up so i can have a reference guide while doing it?
and is a walbro 255 a needed supporting mod for an o6?
Posted: Thu May 10, 2007 9:23 am
by hotsam
Posted: Thu May 10, 2007 9:27 am
I'd search scoobymods.com, they tend to have plenty of write ups. Another option is to search the 2.5l forum over at NASIOC.
Outside of that, a turbo swap is a pretty common procedure that can be finished in a few hours with skilled hands and plain old hand tools. Even if you've only got one person around you who's done the process before, you'll be fine.
As far as supporting mods are concerned, the only thing you really "need" other than the bigger fuel pump is some sort of engine management system (COBB, UTEC, ECUTEK, etc.)
Although, if you're talking about a turbo swap I highly recommend an STi-sized TMIC and a turboback exhaust as well. That ought to put you right at 300hp/300tq at the wheels.
...and that is faaaast.
Posted: Thu May 10, 2007 9:53 am
by NasbaRex
thanks guys....
i searched nasioc for awhile without finding much useful info...
i have an ebay TMIC lying around somewhere....
i have a catless TBE
and an AP
so im just short a vf39 and a fuel pump
Posted: Thu May 10, 2007 10:22 am
How about injectors? What are the new 06 WRX rated at with an upgraded pump?
When are you going to do the turbo swap? I know that all of us have a good bit of things to do.... maybe we can organize another install day
Turbo swaps go pretty easily as long as you take your time. Make sure to put a hose clamp on the bottom oil return line as it has a habit of leaking!
Posted: Thu May 10, 2007 11:41 am
Sabre wrote:How about injectors? What are the new 06 WRX rated at with an upgraded pump?
Teh 06's flow equal to teh JDM pinks used in the 02-05's. He's fine with them.
Posted: Thu May 10, 2007 1:32 pm
Posted: Thu May 10, 2007 1:35 pm
by NasbaRex
can u just pull the fuel pump relay and crank the motor over in order to prime the turbo with oul instead of doing all the crap that is in that wirte up?
Posted: Thu May 10, 2007 1:56 pm
by hotsam
Yep...you can do that.
Posted: Thu May 10, 2007 2:07 pm
Exactly what I do.. but in a different spot
There is a green connector in the passenger foot well on the right. Pull it straight down and it will disable the pump.
Posted: Thu May 10, 2007 2:20 pm
Sabre wrote:Exactly what I do.. but in a different spot
Fuel.Pump.Relay.
Posted: Thu May 10, 2007 2:23 pm
It's just a connector in between
I thought the relay was in the same spot as all the others (in the engine compartment)
Posted: Thu May 10, 2007 2:24 pm
whatev... something like that. the box itself looks like a relay to me.
HA-------------IRS
