Black Satin (spray or spread)
Posted: Fri Apr 13, 2007 11:35 am
by Osiros
Quick question,
Getting ready to pick up a can of teh Black Satin for the DP and everything I've read in the forums talks about spraying it on. However, all of the pictures show a can of it that looks like it's something you spread on with a brush or something.
Am I looking at the right thing? The link I followed was
http://www.caswellplating.com/aids/techline/.
Posted: Fri Apr 13, 2007 12:43 pm
Yep, that's the one you want
I've always just brushed mine on with a disposable brush and then baked them in my grill... works like a charm
Couple of notes: Make sure to wear gloves and a mask. Get several brushes, BS will eat through the cheap ones after about 20 minutes...
Posted: Fri Apr 13, 2007 12:48 pm
by Osiros
Holy hell - should I get a biohazard suit too?
Don't have a grill - everything I've read says that the heat of the exhaust should take care of any cooking that it needs. Should I figure out a way to grill it anyway?
Posted: Fri Apr 13, 2007 2:51 pm
The head from headers and a UP will definitely cook it, but for a DP throw it in your oven at as high as it will go for an hour. Make sure to put down aluminum foil so none of the BS gets on your oven...
Yes, it is that toxic
It contains lead and other nice things...
Posted: Fri Apr 13, 2007 3:52 pm
by Libra Monkee
Sabre wrote:Yes, it is that toxic
Yeah, so don't eat it.
I'm trying to think, when I did mine I just sprayed on a nice think coating, let it dry, then sprayed in all of the parts I missed. I wanted to do a second coating but I think the directions said not to so. However, when I look at my DP now it doesn't look like there's any Black Satin left on it.
Could it have all burned off?
Posted: Fri Apr 13, 2007 3:56 pm
/cough spray wrap spray /cough
