Mach V Dyno Day, 12/9/06
Posted: Mon Dec 11, 2006 10:37 am
by GaToR
Mods list:
1-piece header/up-pipe combo
Stromung downpipe (catless)
(Stock midpipe)
Borla cat-back
K&N Typhoon intake
Cobb AP Stage II
Here's the link to the graph for the 3rd pull (with A/F).
Posted: Mon Dec 11, 2006 11:22 am
I did a little ninja edit to help with the dyno graph posting.
had a good time hanging with you and Darrin on a cold Saturday morning. I'm jealous of the numbers you guys put down.
Posted: Mon Dec 11, 2006 11:23 am
Nice! Congrats on the great numbers!
Posted: Mon Dec 11, 2006 12:00 pm
by GaToR
Thanks! It's much better with the graph posted. Saturday was well worth it, even in the cold since it held off the heat soak until the 4th pull (numbers peaked on pull #3).
Posted: Mon Dec 11, 2006 1:35 pm
And that is on the Cobb base stage 2 MAP.
Take a good look at his AFRs beyond 5,000 RPMs. The Accessport is running the car CRAZY rich! Just imagine what that LGT will put down once it's tuned properly! He's going to get 300whp & 300ftlbs with just a few modifications and very little expense.
I am so jealous of this car!
Posted: Mon Dec 11, 2006 1:58 pm
Here's the numbers from mine as well:
02 WRX Wagon
Mods list:
ECUTEK Reflash tuned by Big Al of Dynoflash
Greddy TZ518Z (TD05-18G w/ 8cm housing)
RC 650 injectors
Borla headers
Generic Up-pipe
Injen downpipe (with hi-flow cat welded in place)
Bosal single tip cat-back
GP Moto intake
ebay TMIC
HKS EVC IV
Here's the link to my two 20psi pulls.
(gabe feel free to do your edit magic here as well)
I'm running a bit lean through 4,000-5,000 RPMs
The blue was first the red second. Notice the ECU was already making corrections to the fuel map, and while my peak power dropped by about 1.3 whp my torque actually increased by 1.3 ftlbs. The graph is also a bit smoother as well.
Posted: Mon Dec 11, 2006 3:11 pm
I'm guessing that Al has you running a little lean to get the spool up... I don't think that you would loose that much by richening it up a little though. The nice thing is, the ECU should prevent any big problems from that if it detects knock anyway.
Posted: Mon Dec 11, 2006 6:44 pm
Good numbers, Gentlemen! Hey Darrin, maybe we can compare acceleration of our cars before I get my car detuned.
Posted: Mon Dec 11, 2006 7:27 pm
Hmm, lets see you have the 2.5 and the 4.11 and the D-man has the 2.0 and the 3.9.
I'm going to give the acceleration title to you Will, but the time to speed to Darrin.
Posted: Tue Dec 12, 2006 5:07 pm
zaxrex wrote:Hmm, lets see you have the 2.5 and the 4.11 and the D-man has the 2.0 and the 3.9.
Actually, if he's a 5 sp manual the final drive ratio is 4.44 vs 3.9.
That's a big advantage. However, the FXT's curb weight is 3,350 lbs and the WRX wagon's is 3,100 lbs.
Posted: Wed Dec 13, 2006 11:56 am
Hey, how the hell did I confuse a $EAT final drive with the Forester? I have one of them sitting in the back yard.
Don't ever let me do that again.
Are you sure about that weight difference? 240LBS I mean that is only me and the suitcases I took the Canada in weight difference.
Posted: Wed Dec 13, 2006 12:23 pm
The problem is subaru only gives curb weight, which isn't always the same as gross vehicle weight. I don't have any other sources on this and the web isn't nearly as helpful as I'm not certain what sources to trust.
It should also be pointed out that according to SOA the 2006 STi is nearly as heavy (3,351lbs) as the 2006 Legacy GT manual (3,365) and significantly heavier than the old WRX 3,040 (sedan) 3,100 (wagon)
Posted: Wed Dec 13, 2006 2:26 pm
by GaToR
That should speak well for my car
More power than a stock STi and a bowling ball heavier? How far off would they be on accel?
Posted: Wed Dec 13, 2006 2:36 pm
My guess is that with an aggressive launch and quick shifting, no stock STi (or EVO for that matter) has any chance of keeping pace with you.
Stock STis put down 240-245 whp / ftlbs on MachV's dyno.
Posted: Sun May 27, 2007 5:05 pm
by GaToR
drwrx wrote:And that is on the Cobb base stage 2 MAP.
Finally got that tune last Saturday.
It was done by the same guy scheduled for the P-tuning Dyno Day that got cancelled.
After one week, I decided to share my thoughts on how well Zippper is currently running.
Power:
Low end response and torque have got to be way up.
Grade: A+
Cooling:
Heat soak is coming much faster with the leaner mixture, or else it is just more noticeably dogged when hot. Get moving at 45mph+ and response picks back up again.
Grade: C+
Fuel mileage:
Absolutely through the roof. During a Friday rush-hour trip to work and a lunchtime trip home, I maintained my typical driving style of consistently being either the fastest or equal to the fastest car in the left lane, never the slowest, and merging for position at lights when necessary. Yet there was definitely nothing to attract the Schutzstaffel during my commute. Probably a typical tuner's daily driver behavior when not side-by side with a potential kill.
I checked my mileage monitor after this trip, which was the only distance that I logged:
Distance Traveled: 24.1 miles
AVG MPG: 29.4
A 4-5 MPG improvement over what I would typically get pre-tuned under similar conditions.
Grade: A++++ . . . Bonus!:ya: . . . Level Up!:plusone: . . . Killing Spree!:bfg:
In addition, I watch the Current MPG setting on my dash often, and 35-40 pure highway is about the range I have seen thus far. No real logged trip yet though.
Now I just need to re-visit MachV to see if I'm running at higher HP/tq.
Overall grade: A
Posted: Sun May 27, 2007 11:51 pm
by snaab
Awesome numbers for an awesome car! Congrats
Posted: Mon May 28, 2007 6:34 pm
FMIC or intercooler sprayer in your future?
Posted: Mon May 28, 2007 9:48 pm
by GaToR
snaab wrote:Awesome numbers for an awesome car! Congrats
Thanks
Mr Kleen wrote:FMIC or intercooler sprayer in your future?
I doubt I'll go FMIC route. But the sprayer on the other hand...
Posted: Tue May 29, 2007 8:44 am
or a CO2 sprayer, or NOS sprayer.
Posted: Tue May 29, 2007 9:48 am
Sprayer or larger TMIC will solve that problem! Glad to see you are so happy with the tune!!!
Posted: Tue May 29, 2007 10:32 am
Brake out the alcohol! Injection that is. Wave bye-bye to heat soak problems.
Posted: Tue May 29, 2007 12:15 pm
by GaToR
Sabre wrote:Sprayer or larger TMIC will solve that problem! Glad to see you are so happy with the tune!!!
I've been trying to justify to myself an AVO TMIC for a while now.
Posted: Tue May 29, 2007 1:57 pm
I believe you now have all the justification you need
Posted: Mon Jul 23, 2007 10:35 am
by GaToR
Perrin TMIC + fully recirculating BOV is in teh mail!!!
