Overall this was not difficult, but because the '05 reverse harness has not yet been released by Metra, finding the equivalent was a challenge.
Basically I wanted to add an Alpine MRV-F450 5 channel amp with a 10" sub to my stock head unit, just until I find a head unit that I can't resist. And I wanted to do all this without cutting my factory harness.
The forward factory harness (80-8901) by metra was missing the orange/white wire for the dimmer (negative) so I had to add one to it. This provides power for the back-lit radio buttons when the headlights are in the "on" position.
No one seems to make, or has in stock a reverse factory harness for the subaru so I used one from a hyundai accent. The only difference is that the wire colors are not the same.
I used a "pac oem II" converter and ran all the wires through it on the "input" side to the reverse harness. The only one I had to run around the converter was the neg. illumination wire (dimmer) because the converter does not have a pass thru wire for this feature.
On the output side of the converter, I connected all but the speaker wires to the forward harness. I then connected my speaker wires from the forward harness to a 12' S16 OEM monster standard cable (4 pair w/ remote wire) and ran it back to the amp which I mounted on the trunk/back-seat wall.
Ran power, ground and amp switch wire to the amp and now my auto dim rear view mirror vibrates like this big flashlight I found in my girlfriends nightstand.
Good luck!
						Added an amp/sub to my stock headunit, 2005 STI
				thegovernor
Very nice write up!  Mind if we post it on the how-to's section of the site?  I used the Circuit City Subaru <-> Universal <-> Alpine harness for me and it worked like a charm  I've been thinking of adding a Pheonix Gold 5.1 Amp to it, but have been too engrossed with other mods
Mr.Kleen: If you need help, let me know Jason and I did the speakers in my car.  Nothing like taking the dremel to a brand new car!  Check out this site for spacers: http://www.iaperformance.com/catalog_subaru.asp
  Jason and I did the speakers in my car.  Nothing like taking the dremel to a brand new car!  Check out this site for spacers: http://www.iaperformance.com/catalog_subaru.aspSabre (Julian)
				thegovernor
 now that it's warm out I've been busy doing other mods, but the speakers will be going in soon.  this weekend I have other plans, but I don't want to jinx myself so I'll leave it at that for now...
