I was in contact with Cobb a year ago and was told that there might be something exciting happening this year. I am referring a "real time" map switch capabilities. It is worth your while to contact them if this product is now available.Originally Posted by vinithing
I am getting an aquamist 2d kit for my '05 STi. I am running COBB Stage2 AP for my EM. I also have a turboback exhaust to support the AP. I am going to get my car tuned after the kit is installed. My question is how exactly would the kit work with my AP? And is there anything else I would need to make the kit work at the best level it can.. Thanks much!
Vinnie
I gather the standard AP has mulit-map capabilities, but it has loaded manually. Pity if this can be done automatically, it will make life so much easier.
Alternatively, the 2d has its own failsafe circuitry inbuilt and is able to cut your boost via the fault output channel (orange wire). Yiu need a small 5-pin relay to accomplish this.
Ensure you have a dash led indicating any water fault events.
Richard
