WRXWagon2112 wrote:So I've taken a look at some of the requirements for SCCA Autocross classifications and it looks like it's come down to two possible choices:
1) Remove my exhaust (except I could add a larger axle-back), remove the strut bar, replace the wheels and tires with same-size but lighter/better ones and be classified as D-Stock.
2) Add a sway bar (which I've already purchased from Hotsam), replace the wheels and tires with larger/lighter/better ones, add the UTEC (though I'm a little confused as to whether that's allowed), and possibly add a CAI to be classified as STX.
Pros and Cons:
Option 1)
* may put me into a less competitive group
Not really. The ITR is fierce competition and so is the BMW 330. Also, I've been at a couple of events where a VW R32 and Talon TSI both did well.
* possibly good for a first season?
* not as much fun 'cause I gotta strip off my few mods
How much do you want to spend on tires? R-comps aren't cheap and you need to change them at events.
Option 2)
* puts me into a highly competitive group
* perhaps too competitive for a first year?
* but I get to add a lot more mods
Actually, a lot of novices end up in STS/STX for the same reason you are describing. They've modded their cars in some small way and now they are out of stock class but want to autox. So, you have some very good drivers, and some very bad drivers, just a larger group as a whole as compared to DS. I was never able to compete in H stock w/ the P5 because I put in a short shifter when it was 3 months old and then lowering springs 2 months before I ever heard of autox, much less considered participating in it.
How much do you want to spend? There's a thread on a STX MSP buildup and he is up to about $7500, not including the cost of the car or event fees. I've probably spent, err... close to $2K on my car and it's not even close to competitive. I think Shawn has spent close to that on the Miata and we're looking at another set of wheels/tires for that and a whole list of other items, around $500, that we want to try and do before the end of the summer. DS lightweight wheels will probably run you about $700+, and then tires are about another $500 or so. And after that, it is mostly tire cost.
