Looks like a nice upgrade for brakes!
Posted: Thu May 04, 2006 12:31 am
Daddy's new brake package.
Specs:
The MadDad(TM) RadialPro BBK "brakes" the rules of what a BBK should be for the average enthusiast. This is the first and only BBK to utilize a versatile Radial mount caliper. This was chosen as a design factor and it allows our kit to work with multiple rotor sizes to accomodate varying needs. Utilizing a thoroughly modern Wilwood DynaPro opposed 4-Piston caliper(not to be confused with low cost and fixed mount DynaLite caliper used in other kits), combined with optional directionally vented and slotted two-piece lightweight rotors, and a choice of Wilwood or Porterfield pads, our kit performs like you wish the factory brakes did. Some exclusive feature:
* Radial Mount design allows fitting of OEM 294mm rotors, our optional two-piece 294mm rotors, optional 308mm rotors, or any OEM one piece replacement rotors. Kit has been tested with rotors upto 330mm.
* Pre-fitted dust seals. One of the very few kits that comes fully booted to prevent dirt and debris from entering the piston bores, preventing premature wear and early re-builds many BBKs are prone to. The DynoPro was designed by Wilwood for Road Rally Racing making it an ideal caliper for real world driving, unlike many calipers designed for "clean" track environments.
* The most wheel clearance of any 4-piston kit on the market. Another benefit of the Radial mount design is better wheel clearance. As a result our kit fits the factory 16" wheels and just about any 17"X7" wheels. Fitting templates available.
* Quick-Clip pad retainers allows changing pads without removing the caliper. Change pads quicker than you can remove the wheels.
* Despite the features and completeness of our kit, priced below most competing products.
* Your choice of Q, A, or E compound Wilwood pads standard. Porterfield R4S available.
Every MadDad(TM) RadialPro BBK includes:
* Wilwood DynaPro Calipers
* Wilwood Q, A, or E compound pads(Q standard. A or E no extra charge, Porterfield R4S available)
* Wilwood Radial Mount
* Custom Mount Adapter
* Stainless Steel Brake Lines
* Full Install kit with everything needed for install except the hand tools. Includes grade 8 fastening hardware, washers, ss line retainders, shims, 3mm wheel spacers(for 16" wheel installs). We even include the lock-tite.
* Detailed illistrated installation guide.
* Optional: 294mm Racing Brake performance rotors
* Optional: 294mm directionally vented and slotted two-piece rotors with aircraft quality T6061 light-weight aluminum hats
* Optional: 308mm directionally vented and slotted two-piece rotors with aircraft quality T6061 light-weight aluminum hats
Might be a good choice for... say a FXT that want's to upgrade his brakes and still use the factory wheels!
Specs:
