1991 Mitsubishi Galant VR-4 AWD/Turbo
Posted: Sun Oct 05, 2014 8:44 pm
Hey everyone,
I stumbled upon this place while looking for some locals to hang out with and share my car hobby. I live on Kent Island just over the Chesapeake Bay Bridge. I haven't met many guys in my area, and am hoping I can network here to change that.
Anyways, I have a 1991 Mitsubishi Galant VR-4. It's AWD, turbocharged, 4 wheel steer and full of awesome 90's tech. I've just completed a large part of a pretty in-depth resto/mod on the car. I do all the work myself as money and time allow. Here's a mod list and photo dump:
Motor:
6 bolt block rebuilt by Dale Morss Machine (.20" over, decked, cleaned, new freeze plugs)
1G Rods
Ross 2G 85.5mm 8.3:1 forged aluminum pistons
King rod and main bearings
Stock 6 bolt crank by C&P Machine (polished, oil galley balls removed/plugged)
ARP head bolts
ARP main bolts
Cylinder head rebuilt by Dale Morss Machine (Oil port mod, BC1100 valve springs, 3G revised lifters)
HKS 272 cams
Fel-Pro composite head gasket 9627PT
All new engine gaskets (FelPro)
New water pump and timing components (Gates)
Gates accessory belts
Gates timing belt
NGK BPR6ES plugs
New oil pump with OEM BSE kit
90' OEM oil cooler setup
Fuel:
Walbro 255 fuel pump
Aeromotive A1000 AFPR
-6 AN rail to AFPR
Fuel pump rewire
New OEM fuel filter
Drivetrain:
Rebuilt transmission with welded center diff (Red Line MT-90)
3 bolt rear differential (Red Line Heavy ShockProof)
23 spline transfer case (Red Line Heavy ShockProof)
Centerforce dual friction organic/carbon composite clutch & pressure plate
ACT StreetLite Flywheel
New OEM TOB
JNZ shifter cable bearings
Stainless braided line from master to slave
New OEM slave cylinder (3/4" bore "red piston")
New front CV shafts
Intake & Intercooler:
HKS air box and filter
Sealed catch can
Stock BOV
Bar and plate FMIC 20"x 13" x 3.5" core
Magnus sheet metal intake minifold
Turbo & Exhaust:
3" CM Performance turbo back exhaust w/ CAT
EvoIII 16G turbo
FP race exhaust manifold
Electronics:
Coil on plug ignition
Black top CAS
ECMlink V3 full
Moroso sealed battery box relocated to trunk
Custom 8 Gauge grounding kit
Battery cutoff switch in trunk
ECMlink boost control setup
New OEM knock sensor
Blitz Dual turbo timer
Cooling:
New Spectra OEM replacement radiator
Stant 13lb radiator cap
Stant SuperStat 180* T-stat
Factory puller fan
12" auxiliary slim puller fan
Brakes, Wheels & Suspension:
New front stabilizer links
JIC Magic FLT-A2 Coilovers
Tein front camber plates
Whiteline front and rear swaybars
Ingalls 1G DSM adjustable rear camber arms
Ichiba V1 hubcentric spacers (10mm front, 15mm rear)
Extended lug studs
Muteki SR48 lug nuts
BBS LM097 series Wheels * 17" x 7" * 4x114 * Offset 39
Dunlop Direzza DZ101 tires 215/50 R17
Whiteline front and rear strut tower bars
ABS delete w/ 1G AWD prop valve
3G Eclipse master cylinder w/ braided lines to prop valve
3KGT VR4 four pot front calipers
3KGT 12.5" drilled/slotted front rotors
Interior:
Personal steering wheel and shift knob combo
JNZ Tuning short shifter
89' underdash
Kicker DS series speakers (4", 5.25", 6.5")
Alpine CDA-7894 deck
Greddy Boost and EGT 52mm gauges
Paulo fiberglass dual gauge pod
OEM Mitsubishi rear sunshade
JDM headrests
Exterior
JDM RS hood
JDM front and rear bumpers
JDM clear corners
JDM door handle scratch guards
JDM door & rear window visors
JDM keyless fuel lid
JDM headlights w/ HID conversion
55W 2500k H3 fog lights
Eterna Grille
Motor:
1G Rods
ARP head bolts
ARP main bolts
HKS 272 cams
Gates timing belt
NGK BPR6ES plugs
Fuel:
-6 AN rail to AFPR
Fuel pump rewire
New OEM fuel filter
Drivetrain:
New OEM TOB
New front CV shafts
Sealed catch can
Stock BOV
Turbo & Exhaust:
EvoIII 16G turbo
Electronics:
Black top CAS
ECMlink V3 full
Cooling:
Factory puller fan
Extended lug studs
Interior:
89' underdash
JDM headrests
Exterior
JDM RS hood
JDM clear corners
Eterna Grille
