Chrysler wants to hold the title of building the most capable trucks and has released the class-leading towing and weight ratings for its 2013 line of Ram Heavy Duty pickups and Chassis Cab trucks. The Ram 3500 Heavy Duty pickup will claim a 30,000-pound trailer capacity thanks to a new class-exclusive 50,000 pounds-per-square-inch, high-strength steel frame, improved transfer case, higher-load transmission and an upgraded 6.7-liter Cummins Turbo Diesel engine with 850 lb.-ft. of torque.
Ram's closest competitor is limited to a 23,100-pound maximum trailer.
"We built the new 2013 Ram Heavy Duty to be the undisputed Heavy Duty 'King of the Road.' These new rigs deliver on the number one key attribute most critical to these customers: uncompromising capability," said Fred Diaz, President and CEO -- Ram Truck Brand and Chrysler de Mexico, Chrysler Group LLC. "Towing capability, reliability and engine performance are ranked first through third, respectively, with HD customers. The 2013 Ram Heavy Duty trucks unequivocally deliver all those things, as well as a very low total cost of ownership."
For 2013 the 6.7L diesel engine benefits from an all-new cooling system. A high-efficiency fan, dual radiators, dual transmission coolers and low-slung charge air cooler afford 25 percent more heat-rejection capacity. Lower operating temperatures deliver improved performance, durability and lower operating costs.
Ram is also introducing a new Ram Active Air intake system. When the intake system senses extreme heat, it draws cooler air from the front of the vehicle - a function that also engages at high altitudes for superior throttle response in low oxygen environments. When conditions are wet from snow, ice or water-fording, the system pulls air from an under-hood inlet, clear from snow packing and water.
Good lord that is impressive for a consumer grade truck!
