				Utec gods i summon thee!
				Posted: Tue Dec 20, 2005 9:55 pm
				by spazegun2213
				Zack and others, I just put on my Borla CBE, switched the UTEC to Sti stage 2, and BOOM at WOT the boost needle spikes at like 1.4 BAR (20 psi). Me thinks that bad. It soon settles back to 1.2 BAR (~17.4 PSI) where it should be. scared the hell out of me to see the guage do that. I mean is it ok? I really dont want a "OH SH*T" moment as me engine breaks.
thanks
				Posted: Tue Dec 20, 2005 10:17 pm
				TURN that MBC down!  Cold air + non-adjusted MBC = VERY bad.
Basically, turn down the boost all of the way, log some data to see where you are at and then slowly turn the boost up till you get it to where ever that map is tuned for (probably somewhere in the 17-18PSI range).  Make sure to do the runs in 4th or 5th gear too.
				Posted: Wed Dec 21, 2005 4:39 pm
				by spazegun2213
				So i Turned the MBC all the way closed and it was still doing like 1.3 bar at peak! So i even tried the Stage 1 setting, and now i know what it does for a catback! I think I'm going to need a tune, i mean The Stage 2 is not supposed to have a catless dp!!!
I'd like you boost gods to take a look and see if its worth getting a tune now, or if i should wait till spring.
thanks
				Posted: Wed Dec 21, 2005 5:21 pm
				by ldstang50
				1.3bar is about 18.8lbs.  If you turned your MBC all the way down, the acuator should open at the minimal boost level required by the car.  the evo its .7bar or 10lbs.  I'm assuming you might be a little higher so witht he cold air, that would make sense why you are hitting such high boost
				Posted: Wed Dec 21, 2005 5:22 pm
				Well my friend, if you turned it all the way down and are still boosting that high, there is only a couple of things that it could be: Wrongly installed MBC or big time boost creep.  The first can easily be fixed by checking your lines, the latter needs either a ported waste gate or some good tuning
				Posted: Thu Dec 22, 2005 12:36 am
				The boost controller that came in the kit is an "auxiliary boost" controller.  With it all the way closed, you will be running stock inputs.  Stock inputs are ok with stock components but you have freet up some breathing room and are getting spikey.  In the RPMs where the boost is jumping up, make sure that you are not running ECU or 0 levels in that seaction of the map.
Are you running the latest firmware in OLB or CLB?  If you have a switchover point that is at the same RPM as the boost spike, considder lowering your cross-over threashold, or going full OLB.
clear as mud?
				Posted: Thu Dec 22, 2005 2:31 am
				THE god has spoken, all bow...
				Posted: Thu Dec 22, 2005 3:46 am
				by spazegun2213
				zaxrex wrote:The boost controller that came in the kit is an "auxiliary boost" controller.  With it all the way closed, you will be running stock inputs.  Stock inputs are ok with stock components but you have freet up some breathing room and are getting spikey.  In the RPMs where the boost is jumping up, make sure that you are not running ECU or 0 levels in that seaction of the map.
clear as mud?
*bows*
Umm do you charge hourly? I think i might need a comfortable seat so you can explain all this. I fell really bad saying that its their Stage 2 map, and thats all i really know....
-2 for me being unedjumkated!
				Posted: Thu Dec 22, 2005 5:46 am
				by spazegun2213
				So with a little time an effort, i made a custom stage 2 boost map and thats working just fine! I turned doen the boost a little and its hitting 1.1-1.2 Bar just like it should.
Hmm, i had fun doing that tonight (gave me something to do) No i really want an wideband and a TXS protuner for some real fun.... but i need to the money.... any donations to the "poor white boys college fund"?
				Posted: Thu Dec 22, 2005 3:24 pm
				Cool, glad you got it working.  Once you pick up the theory, the map values make a bit more sense.
I have a TunerPro that I have never used since it is going to be for the new engine (whenever Andrew gets around to giving it some TLC).  If you don't want to buy one, I'll let you "rent" mine for the low cost of getting an EGT bung welded to a stainless steel exhaust manifold.  It is going to be at least Spring before I would even think of using it.
Let me know if interested.
Za "no C"k
				Posted: Thu Dec 22, 2005 3:41 pm
				by spazegun2213
				zaxrex wrote:Cool, glad you got it working.  Once you pick up the theory, the map values make a bit more sense.
Za "no C"k
When can i pick it up? haha, looks like I'll get into tuning before i imagined. I think i know a guy in manassass that can weld the bung on. I would love to tinker around with the UTEC and the tuner, I now have a flat road to make runs in 5th (thats not too illegal).
now i just need the idiots guide on engine tuning and I'm set!
-Spaze
ps... sorry about the name zak!
				Posted: Thu Dec 22, 2005 4:50 pm
				No worries about the name, this is actually the first time that I have mentioned it to this crowd.
Since it looks like you will be going to the meet tonigh, I'll see if I can unpack the hardware and bring it all to the meet.  No gaurantees though, it might be down home in "storage".  If it is, I'll bring it back next year after I return from The South.
				Posted: Thu Dec 22, 2005 4:54 pm
				by spazegun2213
				Meh, if you get it this meet thats cool, if not I'll be back full time in feb!!
