2011 Toyota X-Runner RTR - 2010 SEMA Show Preview
Posted: Thu Oct 14, 2010 11:14 am
The oldest—and arguably best—hot rodding tactic is to put a big engine in a small vehicle. It’s reasonably inexpensive, durable and you can always bolt a blower on the big engine, too.
And that’s exactly what Toyota has done with its Ready-To-Race (RTR) demonstrator Tacoma. Strictly a one-off fun project designed to gain attention for Toyota’s TRD performance parts program, the Tacoma X-Runner RTR packs the driveline from the larger Tundra into the mid-size Tacoma. The result is a mid-11 second quarter-mile truck that shows what a dedicated enthusiast could do with the TRD catalog, a donor Tundra or Sequoia and a Nomex glove full of dollars.
Starting with a 2010 Tacoma extended cab 2-wheel drive pickup, TRD removed the driveline and dropped in a stock 5.7-liter Tundra V-8 with matching 6-speed automatic transmission. The project also required a custom driveshaft and a Tundra rear axle narrowed 5.7-in. to accommodate 30 x 11.5 x 15-in. Goodyear drag slicks without resorting to fender flares. The setup includes 4.30 gears and a prototype Eaton clutch-pack-type limited-slip differential to provide better bite. Another concession to the big slicks to move the rear shocks inboard of the frame.
To keep the RTR looking like a Toyota, stock 15-in. Tacoma wheels were cut and re-welded to form narrow 4.5-in. front wheels and wider 10-in. rears to fit the slicks. The brakes remain stock Tacoma and Toyota says the ABS, stability and traction controls remain operative.
A custom rear trailing arm suspension was also fabricated, lowering the ride height approximately 4.5-in. And a result of this lower stance, a custom exhaust system was needed. The 3.5-in. wide exhaust now terminates forward of the right rear tire, thus avoiding the wildly arcing rear suspension during hard launches. A pair of TRD perforated-chamber mufflers keeps the noise levels civilized, but with an exceptionally pleasing combination of supercharged snarl and deep undertones. Call it ready to rumble.
The belt-driven, positive displacement supercharger does its part to help produce 504 bhp and 550 lb.-ft. of torque on premium gas, figures an enthusiast could easily duplicate. It also gives the big 5.7 V-8 a healthy “hit,” that big thump of torque right off idle drag racers find so useful.
Shedding weight is the other time-honored hot rodding rule, and in the RTR the rear seat, air conditioning, sound system, power windows and other easily unbolted non-essentials were given the heave-ho. Some weight was gained by the larger engine, single-hoop rollbar and about 40 lbs. from the supercharger, but the end result is a 3920 lb. curb weight—considered light in truck racing circles.
The livery was adapted from Dan Gurney’s XR7-G Cougar race car (his All-American Racers had a long association with Toyota). This simple scheme is in keeping with the RTR’s straightforward approach and the number 95 represents the Tacoma’s first sales year.
Look for the Tacoma X-Runner RTR at the 2010 SEMA show in Las Vegas, Nevada, and other high-profile venues thereafter.
