goob_os101 wrote: I believe the swap is pretty straight forward.
except for all the wiring (have you decided on a DCCD controller, it's cost, installation yet?
how about ABS? You'll probably want that to work too.
does this swap include the rear differential? or the brakes? what bolt pattern hubs will you need? will the knuckles match the mounts of your suspension?
any compatibility issues with the instrument cluster?
Trust me, there are a TON of issues to consider, and an equally substantial set of costs to go with it. If you do this, you will have to expend more effort and time than you can fathom right now. If you're seriously considering swapping, I
HIGHLY recommend speaking to someone who has owned a swapped subaru. There are many lessons to be learned. You may also want to do some reading up in the
Subaru Conversions section of NASIOC.
