Money to burn......
- Bluestreak2006
- Bluestreak2006
agreed. teh good dr. is riding on jdm sti struts IIRC. With most springs on the wagon, the rear will sit low. it could be something to be cognizant of if you're rocking the stock struts.drwrx wrote:I had 225/45 17s on mine with the Pinks and I never rubbed, and my rear sat very low. But, I also had stiffer struts which made body roll almost non-existant.
Most will tell you your fine, but I don't think there is any gaurantee.
Permanent solution? Stiffer struts or coilovers...
- Bluestreak2006
Tein H-TECH specs for WRX Wagon:
Avg Lower: F(1.0"), R(0.9")
Spring Rate: F(230 lbs), R(196 lbs)
Prodrive:
Claim to lower the vehicle approximately 20mm (.8") and increase the spring rate by 25% (so 204lbs / 180lbs)
Swift springs for WRX wagon:
Front: -30mm, -1.15" (3.3kg/mm, 185 lbs). Rear: -15mm, -.6" (2.9kg/mm, 163 lbs)
Stock 2002-2003 WRX Wagon Spring rate 163 lbs/144 lbs
I don't have data on the 04-07 WRX wagon spring rates, but I'm pretty sure they're very similar to the 02-03, though likely a bit higher.
Prodrive:
- Bluestreak2006
Wow the drop on the Swift springs looks good but will they improve my handling at all? It seems I might be able to get away with the tire size. As long as I keep the rear drop below 1 in or the springs need to be pretty stiff. Do you guys think some negative camber could stop rubbing also?
Man I miss the good old days when modding was easier. It seems all the fundamentals of tuning are a little scewed when we start talking Subarus.
Jay
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
- Bluestreak2006
have you done any reading in the suspension forum? really, you should solicit as many opinions as possible and gather as many first-hand reviews as you can before making a choice. modifying a suspension, while relatively inexpensive, is one of the more important modifications you can make, and will affect every second of your driving experience.
just sayin'...
just sayin'...
- Bluestreak2006
Wow isn't that a mouthful. I have been reading the wagon suspension forums for the last couple of days straight. I was hovering with prodrives or H tech( S techs are for the ricers...). The only thing with prodrives is they arent wagon specific. I also want a somewhat stiffer ride. The rates seems to be pretty good. I also only drive 4 miles to work and back.
So yet another question- Good place to get an alignment? Ive heard Will talk good things about P Tuning but im open to suggestions.
And thank you guys for all the good advice and for putting up with me.
Jay
Jay
Jay
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
- Bluestreak2006
Damn! Now that's a great price! Camber bolts go for around $40, so it's like getting the H-Techs for under $150!Bluestreak2006 wrote:Just got an even better offer on the H techs. $189 shipped to my door. . .Oh they also come w/ a free set of front camber bolts.
But seriously, go to the Nasioc suspension forum and do some reading on wagon set-ups, there are a ton.
I have Julian's copy of Grassroots Motorsports in which they do an entire suspension set-up on an 06 WRX Wagon.
They did the following:
1. put on 235/40 17 Potenza RE-01Rs on 17x8 Kosei K-1 TS
2. added Sways w/ end links (I'm still not convinced the front is needed)
3. Put on Eibach springs and Koni Sport struts
4. added more camber (with camber bolts)
5. Rolled the fenders (Eastwood's Fender Lip Rolling tool $299 from TireRack)
With these steps, they were able to take over 2 seconds off their lap times and be much more consistant overall.
They also added Strut bars front and rear and they actually went slightly slower by about .15 seconds. They even sated "It is clear that the Subaru's chassis is rigid enough in stock form to cope with the forces generated by any street tires. Perhaps a jump up to ultra-sticky R compound tires or a challenging rally course would do more to justify strut bars, but for us, we'd leave them off.
- Bluestreak2006
- Bluestreak2006
Update-
After doing even more searching a finally went with the Tein wagon specific H techs. I got them for $189 shipped w/ free front camber bolts. I'm gonna try and install my prosport boost gauge tomorrow.
So im approximately 1/3 through my budget and can't figure what else to pick up. Rear sway, replace speakers, v limited lip, CBE exhaust setup.
I have been reading the spring and DP installs and the dp is pretty straight forward. The springs make me a bit nervous. So guys who wants to volunteer there bloody knuckles?
Jay
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
Hmm? I thought the OEM struts came w/ camber bolts in the front?Bluestreak2006 wrote:Update-
- Bluestreak2006
I received the springs yesterday. The camber bolts are Engalls. I hope they will work on the rears as well. Didn't get around to the boost gauge either. And im still waiting on my DP. Next time i'll try a more reputable dealer. They tell me they were in stock then magically they werent. Said it shipped Friday though I'm very doubtful.
Also picked up my secret santa present. Im sure someone will appreciate it.
Jay
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
11 STI Hatch
"Wagon Mafia"
Stage 1 Baby
- Bluestreak2006
- Bluestreak2006
