Phibs wrote:What are the specs on that tC?
Engine
Stock 2.4L 2AZ-FE block/head
Custom turbo kit w/Blow-through MAS
Modified fuel rail/convert from returnless to return system w/Aeromotive FPR
Custom 630cc injectors
Greddy E-manage Ultimate w/MAP setup
Stock s-pipe/mid-pipe w/stock cat/greddy axle-back
Odyssey mini battery
260whp/253ft/lb @12psi (Dyno Dynamics)
Tuned to sound like a jet plane
Suspension
Progress Coil-over (Long Beach Celebrity Challenge spec)
Progress adjustable rear swaybar/end-links
SPC camber bolts
Advan Racing RS 18x8.5
Toyo R888 255/35/18
wheel spacer on front w/extended wheel studs
custom-machined alum hub-centric adaptors
Custom Ptuning/Miller spec alignment (secret recipe)
Exterior
Kaminari body kit w/adjustable rear wing
Light-weight Ptuning vinyl decals
