Larger TMIC
Phibs
Post by Phibs »
So got the parts. Turbo and pump look fine, the injectors ( 1 set look good ) the other set looks USED... wtheck :(
^^^ What injectors did you end up getting? Were they modded? Were they cleaned and flow tested?
Phibs
Post by Phibs »
Wait it gets better. The turbo they sent... 7cm turbine housing when I specifically asked for the 8cm and they confirmed it :(
NEVER EVER EVER ORDER FROM GRUPPE-S. NEVER. EVER.
Phibs
Post by Phibs »
Sabre wrote:^^^ What injectors did you end up getting? Were they modded? Were they cleaned and flow tested?
Brand new Helix Power 860cc.
that sucks, man. I've heard stories about GRUPPE-S but never ordered from them myself. when I hear stuff like this I'm sorta glad I can't afford expensive new parts. sorta...
Phibs wrote:Wait it gets better. The turbo they sent... 7cm turbine housing when I specifically asked for the 8cm and they confirmed it
Send it back! I know your tempted to just take that turbo and call it a day, but don't do it. The 8cm housing makes a big difference in top end on STIs. My guess is the injectors will work fine. My used RC 650s looked like hell when I put them on but they work just fine. But if your going to send the turbo back anyway you could always send back the set that looks used as well.
Sorry to hear about this latest set-back. You are just having all kinds of bad luck.
Phibs
Post by Phibs »
They are going to replace all 4 injectors and also FP will ship me the 8cm turbine housing and I can swap the part myself. ( I was weary at first, but it's a clip and a screw and kapow, easy enough ) The other option was to wait 6+ weeks for FP to build a new turbo, which apparently they are behind on and only have 1 guy building them.
Phibs
Post by Phibs »
Btw they said me swapping the turbine housing is easy and no problem, anyone have any flags go up with that?
I have only taken 1 turbo apart before and it was damaged.
When I took the exhaust housing off the roller bearing assembly anf the exhaust wheel just fell out. I'm pretty certain a undamged turbo would not do that.
Phibs
Post by Phibs »
Lol ok we'll see what happens :) He said the balancing is all on the other side and the turbine housing should be cake.
It may not be "cake" but it shouldn't be a super difficult.
What are you supposed to do with the 7cm housing?
Phibs
Post by Phibs »
Keep it for pickup by them.
Phibs wrote:He said the balancing is all on the other side and the turbine housing should be cake.
:shock: Balancing is done on both sides... or should be. Read the bottom of this: http://www.boostplanet.com/product7.htm
Phibs
Post by Phibs »
Hmmm that doesn't make me feel great :(
Sabre wrote:Balancing is done on both sides... or should be. Read the bottom of this: http://www.boostplanet.com/product7.htm
The exhaust housing shouldn't be an issue in the intergral balancing of the compressor or induction wheels. Once the turbo is "balanced" correctly the housings should be able to be removed and re-installed without affecting the internals.
Phibs
Post by Phibs »
Isn't the wheel that comes with the 8cm going to be larger?
Phibs
Post by Phibs »
Phibs
Post by Phibs »
Shouldn't the injectors be Helix purple? Also will I need any other parts/kits to install the turbo/TMIC/Fuel pump/Injectors? If so I can order that now. ( Like gasket kits whatever )
Phibs wrote:Isn't the wheel that comes with the 8cm going to be larger?
Exactly what I was thinking :) I'm not a turbo expert though and I may be missing something stupidly clear...
thermobox
Post by thermobox »
Phibs wrote:Shouldn't the injectors be Helix purple? Also will I need any other parts/kits to install the turbo/TMIC/Fuel pump/Injectors? If so I can order that now. ( Like gasket kits whatever )
prolly just a different injector(nismo,sard,denso)that helix sells as "theirs".
i'd order some extra studs and nuts for the turbo if the new one doesn't come with them. they are expensive as hell for what you get. but when one comes out stripped or fused they are a godsend. new up and dp gaskets are a good idea depending on condition of the old ones.
tmic should be straight forward, maybe you could get the sti coupler or something of the like. spare hose clamps or upgraded clamps.
try and be low on gas when doing the pump. so spillage is minimized. have rags and a water spray bottle ready. prime the pump if necessary.
i haven't done injectors. andrew warned me of spillage into the combusion chamber when doing them. so follow instructions closely or talk to someone who has advice.
I don't believe the wheels are changed at all, I think it is just a matter of the exhaust housing size and the turbine wheels are independent of the housings. The differnce being a smaller housing will not allow as much gas volume to pass as a larger housing, thus restricting maximum flow. However, the smaller housing allows the exhaust wheel to spin more readily at a smaller volume level, thus spooling quicker.
The flow of a turbo, usually measured in CFM (cubic feet per minute) is built around the intake and exhaust wheels. The housings are directly related to when that max CFM is occurs and how long it is maintained.
Smaller housings allow the turbine wheels to achieve their peak CFM sooner. Larger allow the turbine wheels to maintain their peak CFM longer.
This is a bit over simplified, but you get the idea.
Phibs
Post by Phibs »
Also from gruppe-s when i asked about the color of my injectors:
The purple type injectors are the WRX (top feed) type injectors. The STI
type (side feed) are red. They are the same as the Power Enterprise
injectors.
Phibs
Post by Phibs »
You may need the oil line (although it should have been included with the turbo).
You can re-use your gaskets, I have re-used mine more than once.
The walbro pump should not need an install kit.
Phibs
Post by Phibs »
drwrx wrote:You may need the oil line (although it should have been included with the turbo).
Ok just to note I only received the pump itself.
