Page 3 of 3
Posted: Fri May 11, 2007 7:24 am
sirwilliam wrote:Do you have an aftermarket DP as well?
If not, I would just wait to put it all on at once. Otherwise, it will be a waste of a gasket and there won't be that good a seal using the donut gasket unless your catback utilizes a donut flange which I would then say nevermind, go at it!
BTW, what catback did you end up w/?
I've got an oakos down-pipe on the way and I got a 3" WBR axle-back to match a 3" bosal mid-pipe I had laying around. I'm keeping the stock mid-cat pipe as I wanted to have at least one cat in the system and it's the least restrictive. On my WRX many years ago I had a bosal (shorty) down-pipe and kept the stock cat-pipe and dynoed 262 whp. Later, I got an Injen belmouth 3" down-pipe and welded in a Dynacat super high-flow metal substrate cat. I did another dyno run later and what did I gain? 2 whp! I have since seen many folks put down very good numbers with the stock mid-cat, take a look at Matt's LGT for a good example (258 whp 298 ftlbs w/ a stromung dp and the stock 2.5" mid-cat pipe).
Posted: Mon May 14, 2007 1:18 pm
Darrin,
Sent you a PM w/ the tuner's number.
-Will
Posted: Mon May 14, 2007 3:21 pm
by NeoZERO
well here is another one I'll be at. I just got UTEC, and I need some maps. Maybe you can all laugh at the squeaking brakes again...good times.
Posted: Mon May 21, 2007 7:32 pm
by spazegun2213
i dont know if i posted here, but due to lack of interest the event has been canceled.
Posted: Tue May 22, 2007 12:12 am
I have plenty of interest, just not the ability.
