The borla Hush is a great exhaust, just ask Julian.
It looks great, its quiet, doesn't draw attention to itself, and carries borla's 1,000,000 mile warranty.
If your looking to stay stealthy there are also other (cheaper) options as well. Trubendz (http://www.trubendz.com) sells 2.5" and 3" WRX stainless cat-back exhausts for $375 and $450. They come with Magnaflow mufflers which have proven to be pretty quiet yet make great power.
You can also get the bosal single tip exhaust (like mine) for $400. It's also stainless, and pretty stealthy as well.
If you come to the next meet take a look and listen to some of the ones that our folks have chosen.
I just bought a bugeye...
Yep, both Chuck and I have the Borla Hushdrwrx wrote:The borla Hush is a great exhaust, just ask Julian.
If you buy it, see if Dan (Mach V, aka FastWRX.com) will throw in a 3" flange adapter for it. Otherwise, pick it up from here.
You'll want that type of flange for any kind of aftermarket turbo->catback exhaust that you do.
BTW, after hearing the Magnaflow stuff, I would say it's a little louder than mine, but not look at me loud. I like the sound of it
Mr Kleen wrote:I've got a TXS exhaust, I think they use Magnaflow mufflers. sounds great.
(Though the borla hush is nice too, I prefer the TXS joint)
The 3" flange adapter is only needed if you use a 3" flat flanged down-pipe. If you stick with the stock mid (cat) pipe you will not need the adapter. After my experience and seeing the numbers that can be put down with the stock mid (cat) pipe. I wouldn't replace it. They flow well enough to support over 300whp.Sabre wrote:If you buy it, see if Dan (Mach V, aka FastWRX.com) will throw in a 3" flange adapter for it. Otherwise, pick it up from here.
Again, my recomendations would be:
1. Stromung or bosal down-pipe: $189-$229
with either:
2. Borla Hush cat-back: $550
3. Bosal single tip cat-back: $399
4. Trubendz 2.5" or 3" stainless (magnaflow): $375 or $450
5. TurboXS axle-back or turbo-back exhaust.
6. Any of the above used. They're all stainless and should last forever.
Sabre wrote:Yep, both Chuck and I have the Borla HushI love mine and have never had any trouble because of it. It's nice and quiet until about 3-3.5k, then you start getting a nice grunt.
It doesn't look like a coffee can hanging of the back of your car, it gives you a deep throaty roar, and more vrooom.
