Mine is a base.
But the packages only add :
BBS wheels and fog lamps
or those two + navigation.. literally thats all it adds.
BBS package is $2000 more, and I didn't like the wheels that badly to want them, and I am getting VOLK Ce28n anyways.
the fog lights you can get the complete package plug n play from MachV, full OEM, for about $350
That being said though, if you feel it's in your budget to get bbs or with NAV package I would say shoot for it, factory integrated nav is always so nice.
2008 STI...
Re: 2008 STI...
Damn these little boogers are quick!
Stock turbo and TMIC, exhaust (cated), an EWG and a tune give you 365HP and 411TQ
Re: 2008 STI...
Yes, but that reading was taken with his "cut-out open!"Sabre wrote:Stock turbo and TMIC, exhaust (cated), an EWG and a tune give you 365HP and 411TQ
I'm a big fan of running an EWG (as long as you don't have to weld the flapper shut) but running it open will draw a lot of attention.
Re: 2008 STI...
Yes, but those numbers make me very excited!drwrx wrote:Yes, but that reading was taken with his "cut-out open!"Sabre wrote:Stock turbo and TMIC, exhaust (cated), an EWG and a tune give you 365HP and 411TQ
Seriously, that is a stupid amount of HP and a beautiful mound of torque for a stock turbo car.
Re: 2008 STI...
So you loose a couple of HP/TQ, that's still DAMN impressive. That also hits just before 3500 with that amount of TQ.
Re: 2008 STI...
With a cut-out open you are bypassing the entire exhaust. That means no bends and no restrictive muffler. Trust me, that is worth a significant amount of power. That with the external wastegate allows you to run an extremely high level of boost w/o fear of creep or ossicilaton. It's hard to say what the actual numbers would be with a full catless exhaust and no EWG, but my guess would be around 310 whp / 350 ftlbs max on that dyno.Sabre wrote:So you loose a couple of HP/TQ,
As indicated by this:
Mods-
-Invidia Catless DWG DP-
-Perrin Stealth CBE-
-AccessPort V2-
-Agency Power Lightened Pully-
-Perrin CAI-
boost was set conservatively at 20 pounds. We had it up at just over 300whp and 22psi
Re: 2008 STI...
That's still damn impressive. With a Hydra on the stock turbo and TBE, I only managed 315lbs/ft and 282HP
